+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
Results 16 to 30 of 36
Thread: 3 digit up down counter
  1. #16
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    Quote Originally Posted by ericgibbs
    Try this change to the 7447 connections
    LT pin#3, o/c or high
    BI pin#4, o/c or high
    RBI pin#5, 0V
    Also as Jim says, make sure you have the supplies connected
    Lets know how it goes.
    the display just blinked 8. is it correct to put inverters after the 74LS47? and why does the count starts at 8?
  2. #17
    Roomi Newbie
    Join Date
    Dec 2006
    Posts
    3
    Use ICM7217 from Maxim.
    download the dts from www.maxim-ic.com and u will get what u wanted.....
  3. #18
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    Quote Originally Posted by frenchneco
    No invertors are required with the 7447, the outputs are active low for driving Common Anode LED's.... you are using CA LED's ????
    When you press the up/down switches does the counter count and the LS192 output change?
    If the LS192 outputs change, does the LED display change?
    Do you have an oscilloscope or a voltmeter??
    If Yes, then use them to measure the output voltages of the LS192.
    The LT 'lamp test' pin on the LS47 will light ALL 7segs [#8] if the BI and RB etc are connected as shown.
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  4. #19
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    yes! we finally figured it out. we were just so stupid to see it. the voltage in the display is just high. the preset voltage drop in the multisim program is 1.66V.
    we also got the other digits figured out, which came easy since you helped me. we were just laughing at ourselves after, since it was not hard at all. but the only problem is the starting count is not "000". it would either display "999" or "001". we're thinking of connecting it first in the reset? any suggestions?
  5. #20
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    Quote Originally Posted by Roomi
    as i've posted earlier, we specifically need to do it with the given IC, which is 74LS192. but thanks for the suggestion.
    using ICM7217 would not help us, because we don't have money to buy one. i'm from the philippines, and i'm pretty hard up on my finances since i'm only a student. same goes for my teammates.
  6. #21
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    here's the circuit.
  7. #22
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    Looked at your circuit, as you switch ON, the 555 is probably putting one count into the 1st LS193. Do a manual RESETafter power up or add a Resistor/Capacitor RESET to clear the counters on power up.
  8. #23
    Roomi Newbie
    Join Date
    Dec 2006
    Posts
    3
    Hi frenchneco, U can get free samples of ICM7217 from MAXIM......
  9. #24
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    I have used the 7217 and 7227 many times, they are fine devices, BUT he has to use the 74LS192 for his project.
  10. #25
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    we're almost there... =) tnx for the help mr. gibbs!!! i'l just post if something comes up again...
  11. #26
    motherhugger Newbie
    Join Date
    Mar 2008
    Posts
    4
    whats the news about the circuit?
  12. #27
    kittyvade Newbie
    Join Date
    Mar 2008
    Posts
    1
    Default ty
    tnx for evrything
  13. #28
    frenchneco Newbie
    Join Date
    Sep 2007
    Posts
    38
    to the newbies, read the specification sheets very well. =) that's all you need.
  14. #29
    steph_nugent Newbie
    Join Date
    Nov 2008
    Posts
    4
    Default just need a little help please
    hey guys, you all seem to know what your talking about and i dont really know much, i can read a basic circuit, and solder, thats about it. i am planning to design a 3 digit display counter, with an extra bit. i need to fit something to the F9 key on a standard key board to count how many times the button is pressed. if anyone can help me, of design me a circuit, that would be soooo helpful and aprechiated.
    i have an idea of how to do the F9 bit, but dont know where to add it in. could someone help please.
    Thanks guys.
    im steph by the way, and i live in wales, uk.
    nice to meet you all.
    and thanks again.
  15. #30
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,853
    Blog Entries
    13
    When the F9 key is being pressed I'm assuming the keyboard is plugged into PC.
    If so, it would be simple program for the PC to log/save the F9 operations.
+ Reply to Thread
Page 2 of 3
First 1 2 3 Last
  1. 2 Digit up Counter PIC 16F84A
    By Gayan Soyza in forum Micro Controllers
    Latest: 3rd June 2009, 07:45 AM
  2. asm attachments
    By eng1 in forum Feedback/Comments
    Latest: 14th September 2007, 03:01 PM
  3. Dual counter
    By bananasiong in forum Micro Controllers
    Latest: 24th March 2007, 02:49 AM
  4. Two Digit, 7 Segment Display Counter For A Hand Steady Game
    By stevo2005 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th January 2007, 10:07 PM
  5. Migrating 16c57 to 16F57
    By j_norrie in forum Micro Controllers
    Latest: 31st July 2006, 03:03 PM
Tags for this Thread
