Old 25th September 2007, 01:47 AM   (permalink)
Default Easiest way to 'bump' my 12v car supply to 16v to run my laptop ... ?
I want to run my laptop in my car, i was hoping that it would run
directly off the battery, but it wont.
It wont 'see' any externally connected supply until it goes over 15
volts, so i have to make an adapter of some sort to 'bump' up the 12
volt battery supply, to 15 or so volts. The AC adapter that came with
the laptop gives 20 volts (no load) so i spose i could use anything
that would bump up the feed from my battery to between 15 and nineteen
volts.
It would have to provide about 1.75 A normal running, but with peripherals added on it could demand a little over three Amps.
John
john1 is offline   Reply With Quote
Old 25th September 2007, 02:41 AM   (permalink)
DC to AC inverter -> laptops dc power supply -> laptop
tom3000 is offline   Reply With Quote
Old 25th September 2007, 03:46 AM   (permalink)
Yea, no real cheap easy way to do it. Did you try with the engine running as the charging voltage of a typical auto is very very close to 15 volts when running.
Lefty
Measurement changes behavior
Leftyretro is offline   Reply With Quote
Old 25th September 2007, 07:25 AM   (permalink)
Maplin every few months have an offer on a Car Laptop adapter - it boosts the 12v up to 12-24 volts (and a lot of voltages inbetween) at up to 3.5 amps.
Prices range from £20 to £30 in the sale and ..........
http://www.maplin.co.uk/Module.aspx?...APTOP&doy=25m9
There you go - 20 volts at 3.5 amps for a tenner - you can buy me a beer later
Laptop Car Adaptor
• Works with most laptop computers
• Stabilized output, low ripple and low interference
• Adjustable output voltage (DC 15,16,18,19,20, 22 and 24 V)
• Output 3.5A max (2.9A on DC 22 & 24 V)
• High efficiency and low energy consumption
• Power LED monitor
• Includes 5 interchangeable power plugs
• 10A fuse for overload protection
This high power DC adaptor is designed to power popular brand notebook computers which require DC input from 15V to 24V while travelling in a car. The adaptor features overload and short circuit protection to protect it from damage.
picbits is online now   Reply With Quote
Old 25th September 2007, 12:51 PM   (permalink)
Tom,
Looked at that, didn't like it.
Lefty,
Yes, checked that out, laptop flicks between internal and external
at 13.5v and the screen backlight changes brightness, that may be
intentional to save a bit of battery. Screws itself up after a bit and
jams in external, while still changing backlight brightness.
Laptop didn't like it.
Picbits,
Thanks thats just what i need.
I will be in touch with Maplins to obtain one.
John
Old 26th September 2007, 02:00 AM   (permalink)
what's not to like it ?
it's the most simple, logical and effective solution !
$40 bux and it's done !
Old 26th September 2007, 07:22 AM   (permalink)
DC-AC inverter - lossy
AC inverter back to DC power supply - even more lossy
Size = Inverter + Power supply = quite large
Efficiency - poor
12V to 20V switching regulator - better
Cost $20
Size - about the size of a packet of cigarettes
Old 26th September 2007, 08:27 AM   (permalink)
here is one
http://www.mcrent.com/workbench/dcdc1216/
steve
1Steveo is offline   Reply With Quote
Old 26th September 2007, 10:55 PM   (permalink)
i dont know where you get your parts or stuff, maybe in england they're the size of a refridgerator
and buliding that thing is a waste of time - Like I said !
because plain and simple .... you got the inverter and you have the entire 110V (or 220V whatever it is where one is) AC at your disposal to do whatever, instead of just 1 single output voltage
i powered my 20 inch screen with it once.
Old 26th September 2007, 11:30 PM   (permalink)
Hi Tom, Hi Lefty, Hi Picbits, Hi Steveo,
I did consider making a device like 'Steveo' or possibly something
similar like an oscillator feeding a transformer outputting three or
four volts on a separate winding, to feed a diode bridge and cap,
which could be added to 12v to give me 15 or 16v for my laptop.
I reckoned that 3v at 2.5 Amps would need about 10 watts, maybe a
single transistor running a small transformer at about 18Kc might
do it. Didn't fancy a "buck inductor" circuit, looked a bit too
complicated to me ....
And yes, if i wanted a mains-voltage supply for additional reasons
then yes, i would take my inverter unit with me and use that, as
using an inverter to feed the laptops DC unit is perfectly acceptable
but i want something small just for this job.
Ive been in touch with the nearest Maplins, and they have these units
in stock for £9:99 GBP so i will be going over there tomorrow to get
one.
It will be unlikely to have the 'Dell Latitude' proprietory fitting
in its choice of fittings, so i will have to steal the one from the
latitude mains adapter.
Unless anyone knows where i can get one like it ... ?
And ive just remembered, i dont have a cigarette lighter point in my
car, so thats another job. Its fun like this that keeps me going ...
Cheers, John
Old 27th September 2007, 01:40 AM   (permalink)
one.
Cheers, John
"And ive just remembered, i dont have a cigarette lighter point in my
car, so thats another job. Its fun like this that keeps me going ..."
LOL, ever get the feeling that nature just hates progress?
Lefty
Old 27th September 2007, 08:11 AM   (permalink)
Are you sure? - what sort of car is it? - I don't recall ever seeing a car without one? (not counting antique cars).
They are often hidden behind a flap, or pullout ashtray.
Old 3rd November 2007, 01:12 AM   (permalink)
Hi Tom, Hi Lefty, Hi Picbits, Hi Steveo, Hi Nigel,
Nigel you are quite correct.
Its inside a pull-out flap which contains the front ashtray.
I dont smpke, and i only looked in there once when i got the car,
i never used it, and i clean forgot about the cigarette lighter in there.
I went to uxbridge and got one of those Maplin car-laptop units.
And i cut the lead from the DELL mains unit to the laptop fancy plug,
and put a more normal plug and socket to join it back together,
the same type that is used on the Maplin car-laptop unit.
So now the fancy DELL plug for the Latitude now has a short lead,
with a more normal plug socket on it, which can plug into the mains
supply unit from DELL, or the car-laptop unit from Maplin.
The fancy DELL plug has three connectors, only two seem to be used.
Its been in regular use for a while now with no problems.
John
AT power supply to power Laptop. ArtemisGoldfish Electronic Projects Design/Ideas/Reviews 6 2nd March 2007 04:38 PM
