hi all,
this is my first post here and i hope that i found the right place, i want to design a simple cheap interface between the computer's soundcard and the normal telephone through the rj-11 connection, i have googled alot for about a week, and i found alot of doc(s) talking about this issue like home-made chat cords and the modem's hybrid circuits for audio separation (coz of the ordinary duplex 2w system) or phone-recording circuits, but my conclusion that the pure separation for voice should be achieved using 600:600 audio transformer with secondary coil c.t and also it's hard to get a balanced circuit with it, so in my design i may not require this separation (if the clear-separation will be hard & also the transformers must be used !!) and i hope to make the interface for both spkr & mic without using any isolation transformers neither normal nor c.t by using any equivalent methods (i dunno, plz help ??) even if the quality will be less, and about the loop current i red that using normal 9v battery will be bad and providing it (about 20-30 mA) with current-source circuit will be better (is that true ??), the last thing is about dc-blocking capacitors and filters to be inserted before the sound card's jacks for safety and removal of noise (what values of capacitors & resistances should i use ??), thanks. ibrahim shahin, computer and electrical engineering - ASU |
All telephone external audio circuits use a transformer because it has perfect balance and isolation.
The transformer or electronic circuit must be a "hybrid" type if you want to transmit with a microphone at the same time you receive with an amplified speaker. The Hybrid's impedance match must be adjusted to match the impedance of the telephone line and the gains must be kept very low to avoid acoustical feedback howling. Usually a speakerphone uses gain switching or added DSP echo cancellation. Then the volume can be louder.
Uncle $crooge |
Well you state that you want to interface to a sound card but you don't state if you want to be able to both input and output to and from the sound card to the phone line. If you need two way functions then you will need a hybrid circuit to isolate talk from listen. Also while a capacitor will block the DC component you still have to be able to isolate your interface circuit from the sound card when you are in a 'off-hook' condition or a 90V 20hz AC ringing voltage will be sent to your sound card at some time and most likely damage it. Designing and building such an interface is not as simple as you might think. It would probably be better to modify some existing telephone type circuit that already interfaces with a separate earphone and microphone, then all you would have to deal with is matching the level requirements of the sound card in and out levels. I bet E-bay would cough up cheap devices that you could adapt to.
Lefty
Measurement changes behavior |
I posted a circuit for this some time ago. I made it for my daughter who wanted to record phone conferences.
I used the case and PCB of an old answering machine. I removed a few parts from around the input transformer and added the necessary components so as to use the transformer. See http://www.electro-tech-online.com/e...=phone+monitor
Len |
(permalink) | ||||||
thanks all
![]() Quote:
The transformer is essential for 2 reasons:- 1. For electrical safety. This is a legal requirement in Australia and probably most other countries as it prevents the possibility of a linesman being electrocuted due to a computer fault applying the mains voltage to the line. The transformer must have adequate insulation between primary and secondary. That is why I used one from the telephone answering machine. 2. There would be noise induced - particularly mains hum. The phone line is balanced in order to minimise induced common mode noise. The computer input is unbalanced, ie. one side is connected to the computer ground.
Len |
so what is the simplest circuit that i can use (with only one normal 600:600 transformer) to make an interface to the computer's spkr & mic jacks ??? A Question For All, if i found the c.t transformer that i hardly searched for it, is the basic circuit that combine only a single resistance (100->400 ohm) with the transformer from its c.t sec. coil to the ground will be enough for a well isolated hybrid circuit after adding dc-blocking capacitors, or i should use a modified version ??? |
Hai Pooh2006,
Can you try the attached schematic and see It did not indicate the power supply connections perhaps. device is like LM358 (dual amp). this element is generally used in Modems.
Regards, Sarma. Last edited by mvs sarma; 7th July 2008 at 12:12 PM. |
You could do some research on "phone patch" - equipment used to connect radio equipment to telephone lines. While probably obsolete the information might help with your situation.
stevez |
A hybrid is required to subtract the received signal from the transmitted signal:
1) So that the distant end doesn't hear his own voice loud and delayed. 2) In case the distant end has the same circuit which would cause acoustical feedback howling.
Uncle $crooge |
A properly adjusted hybrid or DSP acoustical echo canceller allows full duplex loud speech on a 2-wire telephone line. Or gain switching must be used (one side is muted when the other side is louder).
Uncle $crooge |
I don't know what you want.
A microphone on a table in a room and an amplified lodspeaker will have acoustical feedback howling when connected to a phone line without a properly adjusted hybrid circuit. Even speakerphones have a hybrid but need to also have a DSP echo canceller or use gain switching to avoid howling. The microphone in a room picks up the sound and echoes of the distant voice. You don't want to send those sounds to the other end.
Uncle $crooge |
| Simple I2C interface chip? | oeginc | General Electronics Chat | 20 | 29th March 2008 12:52 AM |
| Coupling with an audio output | fvnktion | Electronic Projects Design/Ideas/Reviews | 3 | 5th February 2007 09:37 PM |
| Low Power Audio Amplifier | indecided | Electronic Projects Design/Ideas/Reviews | 33 | 8th May 2005 03:18 PM |
| Audio Amplifier Designing Project | silverferro | Electronic Projects Design/Ideas/Reviews | 3 | 26th August 2004 10:04 AM |
| Front pannel audio connector for computer | grrr_arrghh | General Electronics Chat | 0 | 7th March 2004 04:01 PM |
