Old 26th September 2007, 12:39 AM   (permalink)
Originally Posted by audioguru
I don't know what you want.
A microphone on a table in a room and an amplified lodspeaker will have acoustical feedback howling when connected to a phone line.
The microphone in a room picks up the sound and echoes of the distant voice. You don't want to send those sounds to the other end.
i think that u totally misunderstood the situation, this is the explanation diagram for what i hope to develop, and sorry for annoying you if my explanation was not obvious enough.
pooh2006 is offline
Old 26th September 2007, 12:52 AM   (permalink)
Since you are not using the public telephone system and are not using a speakerphone then why don't you re-wire the phone so it has one pair of wires to transmit and a second pair of wires to receive?
audioguru is online now
Old 26th September 2007, 12:59 AM   (permalink)
thx, what i need to do is creating a universal circuit that simulate the re-wiring so it could be used with any telephone (with rj-11 connection), not only one telephone !, then what will be the reasonable scheme for this circuit ??.
pooh2006 is offline
Old 26th September 2007, 01:19 AM   (permalink)
A telephone has separate wiring internally for transmit and receive then uses a hybrid circuit to combine them into a single pair of wires.
Your circuit must do the opposite. It must use a hybrid circuit to convert the single pair into separate transmit and receive for your sound card. It also must power the phone.
Old 26th September 2007, 12:49 PM   (permalink)
but somethin' like this circuit (it's not my design) can be called a hybrid circuit (as it simulate the transformer ??), because i tested it and i have got a good quality (but for sure the mic handle a mixed signal) with a loop current for about 15mA (the resistance of phone == 500ohm).
pooh2006 is offline
Old 26th September 2007, 01:25 PM   (permalink)
Hi Pooh,
In your circuit a lot of the signals from the SPKR output of your sound card go directly into the MIC input. If it had a hybrid circuit then only the sounds from the person on the telephone go into the MIC input.
Old 26th September 2007, 02:24 PM   (permalink)
thx, i'm now agree with you about designing a hybrid circuit will be better and safer, now i have some questions about this circuit (which i think is the basic design):
1- for providing the loop current, i'll need a dc path or better as mentioned before using current source circuit for about 20mA with a transistor (then i'll put a dc-blocking capacitor before the transformer) and if there is another modification to provide the power to the phone without causing any damage to the dry transformer or adding any extra noise ???
2- is this circuit will be enough to give me a nice audio separation for about 75-80%, or there is any other modifications that u can suggest ???
pooh2006 is offline
Old 26th September 2007, 02:57 PM   (permalink)
The link you posted has a different circuit for a hybrid transformer:
Old 26th September 2007, 03:03 PM   (permalink)
but the author of the article mentioned that the 150 ohm resistance coming out from the centre of the sec. can varry, and the last posted circuit is a complete tested one but from another site, and what about the power issue for the dry transformer ??
pooh2006 is offline
Old 26th September 2007, 04:03 PM   (permalink)
I dont know if this will help here but a few months ago I put in a FM transistor inside a normal telephone, only problem with this way is that you goota open it up! If you think this might help then ask for the explaination and Ill post that (not posting now fearing it might be out of topic completely).
HOWEVER, i realized one thing, the output from the telphone speaker (into your ear) has BOTH the signals, the talker and the talkee! So on my set channel (89.5 MHz) could hear the conv, from about 5 meters. The problem of providing ample/stable power to the FM transmitter was not sorted, since I made this in a day. was this useful?
xheavenlyx is offline
Old 26th September 2007, 04:15 PM   (permalink)
A telephone adds some of your transmitted voice to the earphone called "sidetone" so that you can hear if you are talking loud enough.
Some telephones must be powered. Use a high impedance current source or current sink. The line to the phone should be balanced to avoid mains hum or a shielded cable must be used.
Old 27th September 2007, 03:04 AM   (permalink)
This is NOT a hybrid!
Len
ljcox is offline
Old 27th September 2007, 03:17 AM   (permalink)
This is a hybrid.
T2 is the hybrid. It is essentially a Wheatstone Bridge.
IF Zl matches the line impedence, there is infinite loss (in theory) between the Mic & Speaker.
The loss from line to Mic is about 3 dB, and the same from the Speaker to line.
Len
ljcox is offline
Old 27th September 2007, 07:51 AM   (permalink)
i found this circuit before on http://www.tkk.fi/Misc/Electronics/c...interface.html through google, and i think it have somethin' wrong coz after analyzing the op-amp subtraction circuit i found that it subtracts the hole mixed signal from the transmitter signal (or may be i'm wrong !), and also i'll require a dual op-amp ic beside the transformer in circuit which is not good for my desired circuit, anyway thanks.
Yes sir, it is adopted from the same site , an year back for explanation purpose. Near equivalents are very much used for telecom applications. They work well.
this is simple as the transformer winding is not having any taps
Regards,
Sarma.
mvs sarma is offline
Old 27th September 2007, 02:12 PM   (permalink)
Originally Posted by ljcox
This is a hybrid.
thx for your help, and thx to all of u, i'm working now on a design of the hybrid using only a subtraction op-amp, and i'll post my results after testing here.
pooh2006 is offline
Simple I2C interface chip? oeginc General Electronics Chat 20 29th March 2008 01:52 AM
Coupling with an audio output fvnktion Electronic Projects Design/Ideas/Reviews 3 5th February 2007 10:38 PM
Low Power Audio Amplifier indecided Electronic Projects Design/Ideas/Reviews 33 8th May 2005 04:18 PM
Audio Amplifier Designing Project silverferro Electronic Projects Design/Ideas/Reviews 3 26th August 2004 11:05 AM
Front pannel audio connector for computer grrr_arrghh General Electronics Chat 0 7th March 2004 05:01 PM
