+ Reply to Thread
Page 3 of 3
First 1 2 3
Results 31 to 35 of 35
Thread: Simplest timer
  1. #31
    EvilGenius Newbie
    Join Date
    Jan 2008
    Posts
    4
    Default 10 Step Rocket Triggering System
    Here Is A Diagram Of The Above Mentioned Circuit.
  2. #32
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,934
    Or better still use a CD4060, only one IC.
    You could use a micro but that would involve programming.
    if I know the answer.
  3. #33
    k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent k7elp60 Excellent
    Join Date
    Oct 2003
    Location
    Utah
    Posts
    925
    Quote Originally Posted by EvilGenius
    I can see one error on the schematic. Pin 2 is connected to pin 1.(If you follow the line from pin 1 down to the capacitor connected to pin 5 there is a junction point that shows pin 1 connected to pins 2 and 6. This wrong. Take the junction dot off.
  4. #34
    EvilGenius Newbie
    Join Date
    Jan 2008
    Posts
    4
    Default Correction on schematics...
    Thank you for bringing that to my attention k7. That was not meant to be a connection node there. By moving some parts it moved the node as well. This new schematic will address that. As you can see the node is now moved back where it belongs to the lower capacitor off pin5. Again Thank you sir!
    To Hero: I have never used cd4040 or cd4060 are these chips Johnson counters with self clocking (do not need external clock or xtal)?
  5. #35
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,759
    A CD4040 is just a binary counter. It can divide an external clock signal by up to 4096. Its 12 outputs are the clock divided by 2, by 4, by 8, by 16, etc.
    A CD4060 has an RC or crystal oscillator and a binary counter. It can divide its clock by up to 16,384. Its counter does not have all binary outputs available.
    A CD4541 also has an RC oscillator and a binary counter. It has automatic reset if you want or not and it can stop at a certain count if you want or not.
    Its output is selectable to be high or low.
    Other timer ICs are available. One has a monostable output.
+ Reply to Thread
Page 3 of 3
First 1 2 3
  1. Help with timer and interrupt please..
    By AntRoFiZ in forum Micro Controllers
    Latest: 29th May 2007, 11:48 AM
  2. :: Timer 2 Woes ::
    By suby786 in forum Micro Controllers
    Latest: 5th May 2007, 11:13 AM
  3. Watchdog timer in PIC
    By elexhobby in forum Micro Controllers
    Latest: 6th November 2005, 02:51 AM
  4. newbie needs help with presetable count down timer 7 segment
    By zenton in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th September 2004, 04:16 AM
  5. countdown timer code
    By ah_Hui in forum Micro Controllers
    Latest: 26th April 2004, 05:31 PM
Tags for this Thread
