Old 23rd September 2007, 01:50 PM   (permalink)
Post IR sensors
hi everyone..
we are currently doing a project on our electronic design subject. it is an automated light control system and we are using IR sensors for that. The project is working but the problem is that the range is too small. The transmitter and receiver works when they were 5cm apart only. can anyone recommend a long range(approx. 3 feet or more) pair of IR sensor with low biasing voltage? (9V) Please give the specific specs if you can. It will surely help us. Thanks a lot and God bless.
arien
arien is offline
Old 23rd September 2007, 03:58 PM   (permalink)
Why not fix the circuit that you have?
Attach its schematic and parts list for us to see why its range is so small.
The range for most TV IR remote controls is 10m.
audioguru is online now
Old 23rd September 2007, 07:47 PM   (permalink)
They have such crazy range because they are blasted with around 1 amp of current so fast that it doesnt effect the LED much.
Krumlink is offline
Old 23rd September 2007, 10:28 PM   (permalink)
TV remotes use an IR receiver IC that has high gain. Its case rejects visible light. It has automatic gain control. It has a bandpass filter. It is smart.
Old 24th September 2007, 02:00 AM   (permalink)
Agree.
I use TV IR TX/RX LEDs for my projects they are cheap, low power and long range. Data modulate the 38kHz driving IR transmitter, make your own communications protocol or use the popular RC5.
penoy_balut is offline
Old 24th September 2007, 12:08 PM   (permalink)
Post hello..
attached here is the transmitter and receiver we have used.. the parts and components used were indicated.. please kindly check the circuit provided..
thanks a lot..
arien is offline
Old 24th September 2007, 02:02 PM   (permalink)
The receiver doen't have an amplifier for the extremely weak signals from the IR diodes. The IR diodes are probably sensitive to visible light unless they have a black case.
No wonder the sensitivity is poor.
Old 25th September 2007, 12:32 AM   (permalink)
agreed. use a modulated IR receiver like the 1138 from vishay (or similar). You will need to modulate the transmitter so it will require a second 555.
philba is offline
Old 25th September 2007, 03:29 PM   (permalink)
How can we modulate the transmitter? How can we incorporate that to the present tx circuit? thanks a lot.
arien is offline
Old 25th September 2007, 03:37 PM   (permalink)
RC5?.. microprocessor?.. sir,we don't have enough knowledge on microcontrollers..
arien is offline
connecting multiple temperature sensors to a pocket pc raindelay Electronic Projects Design/Ideas/Reviews 16 26th August 2007 06:45 AM
Cicuit for multiple sensors on a single line Vam Electronic Projects Design/Ideas/Reviews 3 4th October 2005 09:59 AM
Joystick port and sensors haydxn Electronic Projects Design/Ideas/Reviews 5 26th November 2004 02:40 PM
Two sensors, one interrupt pin!!! 2camjohn General Electronics Chat 8 11th August 2004 02:12 AM
Advice and help on building sensors! Moooey Electronic Projects Design/Ideas/Reviews 8 11th March 2004 02:40 AM
