| Hello, I need some help with a circuit, for monitoring water level in an overhead tank. The diagram and description is attached. I need to modify the circuit in such a way to add a switch, that when pressed would turn off the buzzer, or the speaker, for a time period of 1 hr. After that, the alarm should again sound. This must occur for low and high water levels. I think a capacitor, properly connected can do the work. I can't determine where to place the capacitor. Somebody please help me. Thanks in advance. Rohin
__________________ Rohin Jose Last edited by rohin; 22nd September 2007 at 06:00 PM. | |
| Hi, Cannot see all of your diagram very well but think the following should help. A 555 timer in monostable mode and triggered by a push switch would do the job, powering a relay which would cut the signal or power to your buzzer. Many such circuits of this on the web, or see a 555 data sheet. Just wonder about your logic though - why have an alarm and then ignore it for a hour ? | |
| The diagram also depends on the water to be a very good conductor, better be some salts in it. There is no amplification of the 14VAC to the LEDs via the water so it may not work as designed. Dirty/salty water might help but clean water has fairly high resistance. Water that conductive will probably corrode the terminals too. PS it looks like one of those might work / might not schematics from the http://www.electronicsforu.com/electronicsforu/lab/site. Ahh yes, here it is. http://www.electronicsforu.com/elect...20With%20Alarm Last edited by blueroomelectronics; 22nd September 2007 at 11:05 PM. | |
about my logic, it is to give the overflowing water to subside, once the water level gets high, and to give time to turn on a motor, if the water level is low. otherwise, the alarm will be sounding until the conditions get cancelled, and might be irritating.
__________________ Rohin Jose | ||
| I was pointing out IMHO its a poor design. A float based design might work (gastank, toilet are float designs) I'd google for a better design, I'm sure there are lots on the net. | |
| Water level Monitor - Real time | krishtriram | Electronic Projects Design/Ideas/Reviews | 11 | 9th November 2008 08:28 AM |
| Water level Controller Project | TB | Electronic Projects Design/Ideas/Reviews | 5 | 18th October 2008 07:25 PM |
| Water Tank level reader and pump Controller | Osman | Electronic Projects Design/Ideas/Reviews | 15 | 9th May 2007 10:44 PM |
| water level controlled motor on/off switch | Lalit | Electronic Projects Design/Ideas/Reviews | 12 | 30th August 2003 02:33 PM |
| water level indicator | romeo | Feedback/Comments | 0 | 5th June 2003 04:07 AM |
