Old 22nd September 2007, 12:44 AM   (permalink)
It has worked for me... Maybe between a new 9V being close to 9.6V and a crappy transistor, it works.
So, why don't you go ahead and give the guy a circuit, Hero999, go ahead...
be a hero!
iONic is offline
Old 22nd September 2007, 01:08 AM   (permalink)
Originally Posted by iONic
TEAM_NightStalker,
The first circuit I posted had R2 as a 50k pot, this should be the main control for sensitivity. Changing R3 to a 470 ohm resistor may help, but minimally. I've played with resistor values and did not get the desired results with this circuit.
The 2nd circuit post, maybe the the 3rd circuit post are far superior to the first in controlling when the LED turns on.
ahh see i dont' have a 50K pot, just 2 100K resistor paralleled. maybe i can find something in my old radio. hehe
team_nightstalker is offline
Old 22nd September 2007, 01:17 AM   (permalink)
Try resistors 10K or less in place of the 50K pot. You should see a difference.
iONic is offline
Old 22nd September 2007, 11:26 AM   (permalink)
be a hero!
The origional circuit with the 9V will work.
Your modified version with the 3V battery won't work.
You removed R7 so the LED will overheat, you should have reduced its value to between 47hm: and 68hm: depending on the forward voltage.
With the 9V version R4 and R5 form a potential divider to stop Q1 turning on when the 741 is low as it's minimum output voltage is 2V which is above 0.6V, the turn on voltage of Q1.
Unfortuantely with the 3V version the potential divider formed by R4 and R5 will mean the voltage at Q1's base will only reach 0.5V when the TLC25L2's output goes high.
Remove R5 and make R4 2k and it should work.
Another thing you could do is connect a 100k resistor between pin 6 and pin 3, this will introduce so hysteresis and prevent the LED from flickering slightly when it turns on or off.
Screen name: Aloone_Jonez
Hero999 is offline
Old 22nd September 2007, 01:05 PM   (permalink)
ok here is my main question of concern. at a run time of 8 hours.... how long should the batterys keep up to this LED?
Old 22nd September 2007, 02:46 PM   (permalink)
Simply visit a battery manufacturer's website and look at their datasheets.
www.energizer.com shows that AAA alkaline cells can power an LED at an average of 25mA for about 48 hours. A 9V alkaline battery can power an LED at an average of 25mA for about 24 hours. The voltage continues to drop so the LED dims.
Ni-MH rechargable cells are also shown.
audioguru is online now
Old 22nd September 2007, 03:09 PM   (permalink)
<b>Hero999,</b>
Thank you for the assistance. I was only trying to give Team_NightStalker some help/options. I knew the 3V circuit was a stretch and was hoping for the aid of
others to jump in and help.
iONic is offline
solar blinking LED HELP team_nightstalker Electronic Projects Design/Ideas/Reviews 33 26th October 2007 06:05 PM
asm attachments eng1 Feedback/Comments 6 14th September 2007 04:01 PM
P channel FETs vs N channel FETs for LED Matrix applications ?? tdg8934 General Electronics Chat 3 9th September 2007 06:17 PM
Line Detection Robot using PIC16F877 helmyshahryl Micro Controllers 0 28th August 2007 02:54 AM
Turn on and off air valves thup Electronic Projects Design/Ideas/Reviews 16 27th December 2003 04:19 AM
