| any ideas? | |
| ok.. finally it works! i solved the problem by reversing the transformer wires... i also made this diagram and i hope it can help everyone who hasn't managed to make it work. | |
| I suggested that on my first response to this thread, perhaps you need to read the replies a bit more carefully.
| See the post in your Solar LED Forum for an alternative circuit. http://www.electro-tech-online.com/e...ed-help-3.html | |
| see it works On a fresh AA Alkaline battery with a white LED, I have gotten mine to run for 5 days STRAIGHT! | |
| | (permalink) | ||
I've noticed it later on when i managed to make it work... now i think it is going to be clear for everyone! Quote:
| Good, I hope it was a fun easy project for you I have built at least 10 of them. My favorite one I stuffed inside a AA battery holder. It is really neat and compact. In this picture it is a AA rechargeable, this was when I first put it together. right now it is sitting beside my laptop (brand new Wizz, do you mind if I put that pic on my website? I think it would look really nice. CHECK OUT THE NEW PROJECTS ON IT!!! www.freewebs.com/electronic-hobbyist Last edited by Krumlink; 27th October 2007 at 04:27 AM. | |
| if someone makes it more clear how exactly it works.... it would be better!!! | |
| its magic, there you go it is simple How it works, is that the transistor makes the coil oscillate, which makes on the other wire a more increased Electromagnetic pickup, induced by electromagnetic waves, called Eddy Currents. Just look up how a transformer works. | |
P.S i forgot.... mine also has CE approval, as you can see in the second photo! Last edited by whiz115; 27th October 2007 at 04:45 AM. | ||
| The coil doesn't oscillate, the entire circuit oscillates. If you use the proper ferrite core then there aren't any eddy currents to waste power. The resistor makes the transistor conduct. The increasing transistor collector current in the coil causes the transformer action to also increase the transistor's base current. The transistor conducts as much current as it can then the increase in current stops, and also the transformer action stops which causes the transistor's base current to reduce and then the transistor's collector current in the coil also reduces and transformer action futher reduces the base current until the transistor stops conductiong and the transformer action also stops. Then the resistor starts the transistor conducting again.
| we are doing things and we don't know how they work! isn't that great Audioguru? | |
Do you know why it wouldn't work when the coil as connected in the wrong direction? Nigel, audioguru, jcox and anyone else which a lot of experiance, please don't respond to this question, let them figure it out for themselves.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez | ||
I only now that when two coils are placed very close and we apply AC the magnetic field for the one coil induces ac current to the other... | ||
| 12volt to 6 volt adapter for PIR unit (anti horse thief) | petermanndorset | General Electronics Chat | 5 | 27th October 2007 05:18 PM |
| 1.2v = 3v ?? | PeterDove | General Electronics Chat | 12 | 19th November 2006 08:54 PM |
