Old 21st September 2007, 03:45 PM   (permalink)
Putting rubber tires over top of the tires that are already on a car!
The cell phone already has a charger circuit in it. Adding another charger circuit won't work.
audioguru is online now
Old 22nd September 2007, 12:56 AM   (permalink)
so there's no other way but to change our auto-shut off feature for the cellphone charger... how about an alarm system? the charger alarms when the battery is already full (but i think at no load condition, the charger will alarm, unless theres a load) any good suggestions for our project?
hardcore misery is offline
Old 22nd September 2007, 05:19 AM   (permalink)
Lithium powered cell phones dont overcharge the battery( unless the charging circuit is damaged) if they did you would have a fire any time the battery was overcharged ( it was allready mentioned that overcharging them ,even a small amount, will cause a fire).
All of the cell phones I have seen in the last 5 years have the charger circuit in the phone and that circiut limits the charge. The power supply that plugs into the phone is just an unregulated supply.
sam
sam2 is offline
Old 24th September 2007, 04:16 AM   (permalink)
But how come that there are some cases of overcharged batteries due to unattended charging condition of a cellphone(a fully charged battery is left connected to a wall wart charger)
Old 24th September 2007, 09:46 AM   (permalink)
Duff charger circuit?.
How do you know the battery is overcharged?.
Old 24th September 2007, 12:14 PM   (permalink)
as an example, my cell battery(a BL-4C battery for nseries and 60 series nokia phones) expanded its size(looks mutated) and its life span was lessened, i don't have a picture my battery, but i think you can visualized what i've stated.
as for the li-ion batteries for nokia 3310's, i've seen some expanded batteries.
Old 24th September 2007, 12:22 PM   (permalink)
Sounds like the charging circuits died then, usually an important part of the charging circuit monitors the temperature of the battery, and if it gets too hot then shuts it down.
Old 24th September 2007, 02:29 PM   (permalink)
The battery is a Lithium-Ion type. The 3rd contact is its temperature sensor.
Old 24th September 2007, 08:30 PM   (permalink)
The only time I have seen or read about repeat problems with lithium batteries in consumer electronics is, from defective batteries (real namebrand ones) or, and these are the most common, bogus, bootleg namebrand or just cheap crap from China.
sam2 is offline
Old 25th September 2007, 03:23 AM   (permalink)
what do you mean by the 3rd contact? is it on the center?, on our charger circuit, will be going to use the 1st and 3rd contacts (indicated with + and -)
Old 25th September 2007, 04:12 AM   (permalink)
The temperature sensor is the middle contact but I don't have any spec's on it.
Old 25th September 2007, 04:53 AM   (permalink)
As johnny storm would say... Flame on!
http://www.youtube.com/watch?v=SQ0SN...elated&search=
http://www.youtube.com/watch?v=vE532lRT3kw&NR=1
sam2 is offline
Old 25th September 2007, 03:56 PM   (permalink)
Originally Posted by sam2
horrible... is it safe to use, 6V / 300mAh charger on li-ion batteries?(3.7V)
Old 25th September 2007, 04:59 PM   (permalink)
Of course not!
Then the battery will over-charge and will catch on fire.
You need a Li-Ion battery charger IC that limits the current and stops the charging when the voltage reaches the manufacturer's recommendations.
It has a backup circuit that uses the temperature sensor in the battery to stop charging when it gets too hot.
It has a low voltage detector that reduces the charging current to a battery that has been discharged too low.
The cell phone has this IC inside.
Old 26th September 2007, 01:37 AM   (permalink)
Of course not!
so if we can't avail this maxim IC, can we use at least 3.7V to 4.2V(300maH) specs on our charger circuit?
Voltage ElectroMaster Electronic Theory 44 8th August 2007 06:35 PM
Current limiting Help PLZ Frosty_47 General Electronics Chat 32 24th July 2007 04:51 PM
Battery Eliminator Problem pixnum General Electronics Chat 7 13th December 2006 08:29 PM
LM3914 Battery Monitor problem.. cheewooi Electronic Projects Design/Ideas/Reviews 1 20th May 2005 08:44 PM
need a battery current and voltage converter induction1 General Electronics Chat 3 28th April 2003 05:37 PM
