| Hello, I been designing a power board that uses a 12V relay to switch on the switched side terminals on when it gets a 5V+ from a AVR. I would like someone here to look over my schematic and see if I need to change something. I also need help getting values for the R3 & R4 as I don't know how to calculation that part yet. The relay will output 12V+ at 30 amps. F1 = 30 Amp Fuse X1 = 12V @ 30 Amp (Pin 1 = +, Pin 2 = Ground) X2 = 5V @ 1 Amp Logic (Pin 1 = +, Pin 2 = Ground) All part number is on schematic if you need that to help out. Also check to see if I connected the PNP correct and all, and one more thing, should I hook up the ground from the 12V terminal to the 5V terminal ground as one? Thanks Shane Last edited by madcitysw; 19th September 2007 at 03:15 AM. | |
| I would have feed the LED in the opto from the AVR side. An opto triac could also be used as there is no filtering from the bridge rectifier. Feeding the opto LED from the AVR side will simplify the circuit. Sorry, I just had a closer look and you arenot using an opt, simply an LED and transistor drawn to look like an opto. Last edited by Super_voip; 19th September 2007 at 03:41 AM. | |
Thanks for helping though. | ||
The transistor base current needs to be about 1/10 th of the relay current. However, it is not going to work as drawn. You need a connection between the cathode of LED2 and the left hand side of R4. But this may cause a problem due to the 2 AC sources. So you may need an opto to drive the transistor.
__________________ Len Last edited by ljcox; 19th September 2007 at 11:04 PM. | ||
| is the voltage from both supplies DC, if either or both are AC as it looks likely from the circuit(bridge diodes) the earth (0V) rails won't really be 0V, there will be some voltage difference between them. This is why optos get used. | |
| need schematic urgently | ycxxi | Datasheet/Parts Requests | 5 | 3rd December 2007 07:32 PM |
| schematic Diagram of Black and White TV Receiver | Ayne | General Electronics Chat | 14 | 6th November 2007 02:13 PM |
| Aguilar DB680 Bass Pre Schematic | jtallent | Datasheet/Parts Requests | 0 | 5th January 2007 05:26 PM |
| Need of Schematic DC-Dc converter | luxuriesPremier | Electronic Projects Design/Ideas/Reviews | 1 | 15th February 2004 10:10 AM |
| For Sale PIC Programmer Schematic | mysemcon2000 | Micro Controllers | 0 | 18th September 2003 12:14 PM |
