| Hi all, Can anyone suggest me a cheap speech synthesizer for my PIC project? Thanks ! | |
There is an interesting project to re-create that chip using a pic micro at: http://home.alphalink.com.au/~derekw/pictalker/main.htm Although the speech quality is not as good as the original. A better commercial version is the "Speakjet" which also uses a pic micro - but it is not so cheap. Your other alternative is to use an addressable record/playback chip and they vary in price depending on the amount of playback time. Modifying a cheap mp3 player is also a possibility if you can manage to control it somehow. | ||
Thanks again | ||
http://www.winbond-usa.com/products/...00/ISD1400.pdf You need to build the circuit as shown in the datasheet and record your voice onto it directly with a microphone. If you search on google you will probably find some projects using that chip. There may be other better chips available cheaply now - perhaps someone else may suggest some. | ||
While looking at something else came across this, may help. http://mdubuc.freeshell.org/Robotics/Tips.html#isd4003
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
I've still got an SPO256 'somewhere', I can't say I was ever overly impressed with it - I used it on a 6502 based machine. | ||
| SpeachChips.com has some voice chips in the $25US range. That is a bit cheaper then ChrownHill but still on the high side, If Nigel was unhappy with the SPO256 it makes on wonder how bad the PIC Talker must. | |
| Thank you guys ! I got what i needed. | |
I searched a lot for this chip to buy one for me.But i couldnt get it anywhere.Is there anyother part or manufacturer doing the same thing? Thanks | ||
Maplin's stock some speech processors. The WTS701 at £24.99 Code no: N86BT plus other ic's. Checked ther Stock!,,, no longer stocked,, so much for their Catalog!. EDIT: They have this device. http://www.maplin.co.uk/Search.aspx?...source=15&SD=Y
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 24th September 2007 at 03:11 PM. | ||
| In case anyone is still looking, I listed a new SP0256 on Ebay last night. Do a search for "SP0256" and you'll find it. Last edited by rangerdoc; 2nd March 2008 at 11:37 PM. | |
| It's sad that since I've played with the SP0256 in the late 80's not much work has been done in this area. Not unless you have bottomless pockets. I don't know if no one has come up with a better way, loss of interests, or what. | |
| Speech Recognition control | vincent_85 | Electronic Projects Design/Ideas/Reviews | 14 | 5th August 2007 11:02 PM |
| Need a list of Speech Synthesis IC's I know of a couple but | Roboticinfo | Electronic Projects Design/Ideas/Reviews | 5 | 17th April 2005 09:24 PM |
| Speech data into PCM any easy cheap chips??? | Electricman2K5 | General Electronics Chat | 2 | 9th March 2005 12:40 AM |
| Speech data into PCM any easy cheap chips??? | Electricman2K5 | General Electronics Chat | 0 | 8th March 2005 07:29 PM |
| Speech data into PCM any easy cheap chips??? | Electricman2K5 | General Electronics Chat | 0 | 8th March 2005 07:28 PM |
