Old 17th September 2007, 03:06 PM   (permalink)
Does it?
An LM317 will go all the way up to 1.5A, although at those sorts of currents a switcher does tend to make more sense.
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th September 2007, 08:54 PM   (permalink)
I think it would. Unless I'm being retarded again Shouldn't he be able to get 1.5V @ 200ma from a capacitor switcher with an input of 5V @100ma assuming 60% efficiency?
Of course, if the USB port will just allow him to draw whatever current he wants, then I agree a linear would be a better way to go. These capacitive switchers are only good for a few hundred mA I think anyway. Any more and you have to go inductive.
speakerguy79 is online now
Old 18th September 2007, 12:16 PM   (permalink)
Originally Posted by iONic
I'm looking for a simple way to use the 5V USB power and step it down to 1.5V in order to power a hand-held Audio player/recorder. I'm not sure PWM is the way to go or not, but would not a simple Zener regulator do??
Don't call it any more Handheld-- it is now PC tied!!
For a 1.5V , why at all bother so much and finally loose its mobility?
Use a duracell which will last for say 20hrs of intermittent use. If forcontinuous listening, transfer them to the PC as wave or MP3 files witha suitable software.
Regards,
Sarma.
mvs sarma is online now
Old 21st September 2007, 06:10 PM   (permalink)
I've been reading that the USB power standard, (100mA unless requested by the USB device), is not often followed.
So I connected a Luxeon Star III to the power of the USB port on my laptop and
.....WOW! It lit up well! After hooking up a meter to it it was drawing 1300mA,
with a 1k resistor....maybe 200mA. Either way more than the "allowed" 100mA.
iONic is offline
Old 21st September 2007, 06:17 PM   (permalink)
A 1k resistor in series with the LED gave 200mA? I don't believe you!
What's the LED rated to?
Did you use a series resistor when it drew 1300mA?
Hero999 is offline
Old 21st September 2007, 07:12 PM   (permalink)
Hi, As i understand from the post , it is 200mA with !K series resistor or 1300mA dirctly-- and he comments- either way more than the specified 100mA.
Regards,
Sarma.
Old 21st September 2007, 08:43 PM   (permalink)
Unless I'm misunderstanding something, ohm's law dictates that only 1.5mA should flow assuming the output from the USB is 5V and the forward LED voltage drop is 3.5V.
Hero999 is offline
Old 21st September 2007, 09:37 PM   (permalink)
I agree with you HERO999
Regards,
Sarma.
Old 21st September 2007, 09:59 PM   (permalink)
Digital multimeters are darn accurate. The 1300mA was see when the Luxeon LED was connected without a resistor. The LED got warm within 5 seconds.
vF = 3.9v, Max I = 1000mA
Specs for the LED are here: http://www.luxeonstar.com/item.php?i...rtno=LXHL-LW3C
iONic is offline
Old 21st September 2007, 10:21 PM   (permalink)
You also said "with a 1K resistor perhaps 200mA", which was complete drivel!!.
Old 21st September 2007, 10:41 PM   (permalink)
My apologies, I just remeasured this current and I do believe it's time to put FOOT-IN-MOUTH(yes I fell down and bumped my head), it is 2.25mA.
iONic is offline
Old 21st September 2007, 11:53 PM   (permalink)
May this bee a lesson to you in estimating figures.
2.25mA sounds about right when dealing with values of 5V and 1k, 200mA sounds far to large when dealing with those sorts of values..
Hero999 is offline
Old 22nd September 2007, 09:29 AM   (permalink)
1K is a nice easy value, because it's 1mA/V - so with a 5V supply (and no LED) the absolute maximum possible current is only 5mA.
Old 27th September 2007, 01:46 AM   (permalink)
Originally Posted by speakerguy79
Just be careful, they are teeny!
Indeed they are! does anyone have any suggestion on how to solder these things? I have some conductive adhesive that supposed to be good or would you have another way. All I have is a 35W soldering iron wit tips that are too big to be accurate.
iONic is offline
Old 27th September 2007, 01:51 AM   (permalink)
You need a narrow tip and preferably .015" solder to solder it right. It's the usual put some solder on a pad, tack down one pin to that pad, then solder the other pins. Conductive epoxy can work but getting a correct tip would be better. We've used conductive epoxy to fix some specialized FET's at work where the wire inside the package came off the silicon, but that's about the only place I've used it.
Alternatively, you can use the "horrible but will probably work" method of just flooding all the pins on one side with solder and letting them bridge, then wicking off the excess. Just try not to get the component too hot.
USB microcontroller programmer Chris W Electronic Projects Design/Ideas/Reviews 14 6th August 2008 06:15 PM
USB Power hack with DC/DC Converter - am I crazy? chconnor Electronic Projects Design/Ideas/Reviews 14 8th March 2008 10:13 PM
RJ11 to USB convertor vice versa Jan Bos Electronic Projects Design/Ideas/Reviews 2 13th September 2007 01:34 AM
usb to RS232 serial port : simrantogether Electronic Projects Design/Ideas/Reviews 3 12th September 2007 01:04 PM
How to get 1.5v from 9v? Axe_Murderer General Electronics Chat 3 17th November 2003 02:35 PM
