Old 16th September 2007, 08:19 PM   (permalink)
Default BJT Amps
Hello all,
I have a HW problem ( see attached PDF).
What I am confused about is the 2mA current source. What I am thinking is that the emitter current = the collector current = 2mA for Q1 ( the first transistor in the pair ). If this is the case, does that mean that the base current of Q2 is 2mA?
Also, since there is no voltage drop anywhere ( by way of resistors ) in the first transistor, how could there be a VCE1?
Any help would be greatly appreciated.
jack23 is offline
Old 16th September 2007, 09:34 PM   (permalink)
No, for Q1 the emitter current is the sum of the collector current and the base current. The emitter current will also equal the 2mA constant current, PLUS the base current of Q2.
Old 16th September 2007, 10:07 PM   (permalink)
Ok, so if I need to find the base current of Q1, then I would take the beta given, which is equal to 50, and say that Ic / 50 = Ib which would give
2mA/50 = 40uA??
So I would I go about calculating for base current of Q2?
Given your input Nigel, you said that Ie = 2mA + Ib( of Q2)
So then, Ib(of Q2) = Ie - 2mA
so that means that Ib of Q2 is the same as Ib of Q1, is that right???
jack23 is offline
Old 17th September 2007, 12:17 AM   (permalink)
2mA/50 = 40uA??
No, the Ie of Q1 will be more than 2mA, because it has to supply the base current of Q2 as well.
Personally I would say this is a really crappy (useless) partial circuit, and a really crappy question - I suspect the expected answers may require you to make a number of completely incorrect assumptions?.
Old 17th September 2007, 01:56 AM   (permalink)
To understand this improbable situation, I would write an equation for everything that you do know, and solve. Check for reasonableness (don't accept negative currents unless you understand them).
One worthwhile assumption is that the schematic is in error and 251K and 3K are also connected to 10V. Given the ridiculous circuit which would remain, it is probably true. It may be worth noting in your answer (you should request extra credit).
Ib1 is probably equal to Ic1/50, and is probably equal to (10-Vb1)/215K, and Ib2 is probably equal to Ie1 - 2mA. etc.
mneary is offline
Old 17th September 2007, 04:23 AM   (permalink)
I don't think any assumptions are necessary to find the operating point. What's wrong with this analysis?
EDIT: This is what mneary said.
Ron (aka Rube)
Roff is offline
Old 17th September 2007, 11:33 PM   (permalink)
Roff, Thank you for your response. It is much clearer now.
I have two questions remaining:
1) I am assuming that, since there is no resistor resistors ( collector, emitter)
for the first transistor ( Q1), then the full 10V is dropped across Vce ( Vce = 10V) is this a reasonable assumption?
2) How were you able to add your own tex my PDF file? I would really like to know, that would really come in handy...
jack23 is offline
Old 18th September 2007, 01:44 AM   (permalink)
I pressed my keyboard's Prt Scrn button then pasted your schematic into MS Paint.
I removed the grey background, cropped it then added the connection dots and text.
audioguru is online now
Old 18th September 2007, 04:44 AM   (permalink)
No. Keep in mind that Vbe(2) is 0.7V, so Vce(1)=9.3V.
When I opened your PDF, my cursor was crosshairs (apparently an Acrobat reader feature). I simply dragged the crosshairs across your schematic, then copied and pasted it into MS Paint, where I added the annotation.
Ron (aka Rube)
Roff is offline
Old 18th September 2007, 11:36 PM   (permalink)
Cool, thanks alot for all the help....
jack23 is offline
Where can I find a ammeter that will measure high amps? Nicksan General Electronics Chat 13 12th August 2007 10:31 AM
New forum about building/modifying SS guitar amps joecool85 General Electronics Chat 2 26th April 2006 01:11 AM
[edit]: Voltage Regulator 1.5 amps using PWM dinofx Electronic Projects Design/Ideas/Reviews 9 4th January 2006 06:51 PM
Hot transitors @ 0.5 Amps Screech General Electronics Chat 16 14th October 2005 01:38 AM
Conversion of 0 to 5 Amps current into 0 to 5 Volts junaidatta General Electronics Chat 4 15th May 2005 07:40 PM
