| Hi, I need to make a 60Hz notch filter, preferably using an active filter IC like the MT10 or the LMF100. My input signal is between 0.1mv and 10volts. I am trying to find a schematic online but I have had little luck. I could bang something out using my novice interpretation of the LM100 datasheet but I am certain this wouldn't be an optimized circuit. Does anyone have a recommendation for me? | |
| From what I understand it's a pretty easy to use chip. Forest Mims has projects based on in it volume 2 of his Circuit Scrapbook series, and he says Quote:
Also, perhaps looking at the schematics for this kit might help: http://newenglandqrp.org/nescaf | ||
| Great leads. Thanks! | |
| 100 microvolts to 10 volts? Good luck! If you aren't required to use an IC, a passive filter would do a good job. Search for "twin T". You'll need 3 resistors and 3 capacitors. | |
| As I said in the other website, you will be disappointed when it removes 60Hz but leaves the harmonics of 120Hz, 180Hz and higher ones behind. Therefore you also need a switched capacitor lowpass filter IC.
__________________ Uncle $crooge Last edited by audioguru; 16th September 2007 at 05:15 PM. | |
| Or better yet, stop trying to paint yourself into a corner. You could probably achieve several orders of magnitude above anything a filter could do for you if you eliminated the source of the noise instead of trying to filter it out afterwards. Understanding power supplies, and filtering them properly is actually more important to keeping unwanted noise out of a circuit that coming up with specific filters to deal with it after the fact.
| Rochester! I used to live there. On the Genesse Hospital grounds on Alexander St. But that was half a century ago. | |
| Notch filter w/schmitt trigger | whirlwindz | Electronic Projects Design/Ideas/Reviews | 2 | 21st May 2007 03:23 AM |
| Notch Filter. | lord loh. | General Electronics Chat | 4 | 18th July 2006 06:52 PM |
| Filter problem... Very urgent pls.. | kingkong83 | Electronic Projects Design/Ideas/Reviews | 23 | 19th October 2004 02:40 AM |
| Notch Filter Woes... | nfway | General Electronics Chat | 15 | 1st December 2003 03:41 AM |
| Audio Notch Filter | ElectroMaster | Electronic Projects | 0 | 25th July 2002 02:11 AM |
