| Hi all, How do I plug in L298 motor driver in breadboard.i could find it diffcult | |
Do you have this drawing? Dim between adjacent pins on the same row is 0.1inch. Dim between rows is 0.2inch So it should fit into standard pcb at 0.1inch pitch. If you want to plug it into a project breadboard you will have to solder it to a header,, if you draw lots of current thru your breadboard you could melt the plastic near the pin/sockets. If you dont have an header, solder, solid 0.2mm dia wire to each pin and plug these into the project board...or mount the LM on a piece of pcb and run wires from the LM/pcb to the project board. Does this help?
__________________ Eric "Good enough is Perfect" PIC tutorials: Gramo's: www.digital-diy.net/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 7th July 2008 at 12:21 PM. | ||
| The Breadboard | ElectroMaster | Electronic Theory | 22 | 15th October 2008 02:51 AM |
| Parallel L298N Driver circuit help | Sidco7 | Micro Controllers | 1 | 11th September 2006 11:07 PM |
| 9pin serial connector for breadboard | dak246 | General Electronics Chat | 9 | 29th October 2004 04:27 PM |
| Breadboard Grounding | anukit | General Electronics Chat | 7 | 24th April 2004 04:40 AM |
