Old 4th March 2008, 12:36 AM   (permalink)
Originally Posted by 0RESET0
Originally Posted by ljcox
Sean,
You need the 74HC05.
OOPS, I will look for those when I get home.
I posted the revised circuits on 26 Feb. I retained the 74LS07 for the computer interface suggested by Eric, but changed the Tx driver ICs to 74HC05. I suggest you print these as they are the current reference. I know you don't want to use the multiplexer, but the other 3 are still relevant.
Do you think I need to use different thicknesses of traces on this board? I was thinking that since everything is basically the same voltage, I could use the same width on all of the traces. See below
I have solved the battery life issue. On a recent trip to the local radio shack, I found several RC car batteries in the clearance pile. I now have 10 9.6V rechargeable batteries. I will just source a connector to match the one on the battery and take a few with me when I go to the shoot site.
Sean
The width of the traces depends on the current, not the voltage.
You need wider trscks for high currents, but you don't have any such currents so it is not an issue.
The spacing between adjacent tracks needs to be increased if there are high voltages on the PCB. Again, not an issue for you.
Len
ljcox is offline
Old 4th March 2008, 05:46 PM   (permalink)
I got the (2) 74HC05 ordered. I also ordered a few other things that i am going to need. This order should be here by Friday.
I spent too much time shopping for components and did not have a chance to try my idea for the PCB layout. Tonight should be much better, nothing else to do.
Sean
0RESET0 is offline
UV flame scanner bulb/tilt switch used as safety-need circuit help Rezaxis Electronic Projects Design/Ideas/Reviews 2 28th August 2006 02:52 AM
Pls. check this Analog Switch circuit for Guitar FX apakhira General Electronics Chat 4 27th February 2005 03:53 PM
need a switch circuit andrew2022 Electronic Projects Design/Ideas/Reviews 12 19th April 2004 06:24 PM
counter circuit, HELP!!! sion Electronic Projects Design/Ideas/Reviews 1 23rd March 2004 06:56 PM
Transistor switch circuit daviddoria General Electronics Chat 3 6th March 2003 01:35 AM
