| Hi Len ,Sean. Quote:
Len, I hope you are getting some rain 'down under'.
__________________ Len | ||
http://en.wikipedia.org/wiki/Arvo
Sean | ||
this arvo = this afternoon
We need to understand exactly what you want and how far the unit will be located from the laptop. My understanding is that you want to be able to press a key on the laptop and have it advance the counter in the unit as if you pressed the "up" button on the unit. Then press another button to initiate the transmission, ie. to the fire the cracker. Incidentally, I'm puzzled as to why you need the counter to be able to count down. I would have thought that you would only need it to count up. I'm also puzzled as to why you need the "unit" if you're intending to use the laptop. Why not interface the laptop directly to the Tx? (the laptop can do the counting) Then make a PCB once you have it all working.
Sean | ||
| I do intend on using a laptop but I would also like to use the unit seperatly. would it not also be easier to write the program if it only has to do three things; count, up, fire, count... etc. Yes it should be little simpler than the full box & dice. Eric?? There is no interaction between the input side and the display side. So it is irrelevant whether you multiplex or not.
| I forgot to comment on this:- I would actually like to have a program do everything for me. I would like to be able to call up a sequence, press enter to initiate it and have the computer change the code of the Tx, fire the Tx then count to the next event and repeat the process. I can help you with the interface, it would only need 3 or 4 ICs; but I don't have any PC Programming knowledge.
Using a laptop to "only has to do three things; count, up, fire, count", is a wastful idea. As Len suggests, go the hardware route, debug and get the project working first as stand alone system. [ I understand you have fireworks demo in the near future?] Using the experience you gain on operating the system, come back to us and we will help with a PC parallel port interface to the system. Regards.
| Alright, I will refrain from thinking about the interface until I have gotten this unit working. I was only trying to make sure that no part of the current circuit would make a difference when we finally started the interface. I have not had a chance to pick up any parts yet. I was going to have next week off but will now be working. This makes it hard to get to our local electronics store. I will try to pick up the parts this week and finally get the prototype finished. Sean | |
| In my post yesterday, I forgot about the output interface, ie. the interface between the counters and the Tx. You will need 2 more 74LS07 ICs for this.
| UV flame scanner bulb/tilt switch used as safety-need circuit help | Rezaxis | Electronic Projects Design/Ideas/Reviews | 2 | 28th August 2006 02:52 AM |
| Pls. check this Analog Switch circuit for Guitar FX | apakhira | General Electronics Chat | 4 | 27th February 2005 03:53 PM |
| need a switch circuit | andrew2022 | Electronic Projects Design/Ideas/Reviews | 12 | 19th April 2004 06:24 PM |
| counter circuit, HELP!!! | sion | Electronic Projects Design/Ideas/Reviews | 1 | 23rd March 2004 06:56 PM |
| Transistor switch circuit | daviddoria | General Electronics Chat | 3 | 6th March 2003 01:35 AM |
