| each room in hotel has one switch(buzzer) which is connected to the main panel of LED placed on the reception ..so that the receptionist can know which room needs a room service. . . this is exactly wat i need. . but instead of rooms in my project its "flats". . . the main panel of LED would b placed at the gatekeeper room.so whichever flat will turn its switch on,the corresponding led of the flat in the panel will glow. so pls suggest how to go for the wirings. . . there are 120 flats in the society.. please help???? | |
| Split each floor of the flats into a manageable block of units. Use single pair of wires looping to each block of units (i.e. 12 units). Each switch is normally closed and has a resistor across its terminals. Flat 1 has a 500R resistor, Flat 2 has a 1k resistor, Flat 3 has a 2k resistor, Flat 4 has a 4k resistor, Flat 5 has a 8k resistor. Measure the resistance or use an A2D port on a PIC microcontroller. If 8.5k is measured you know Flat 5 and Flat 1 have pressed their buttons If 3k is measured then flat 3 and flat 2 have pressed their buttons If 15.5k is measured then all flats have pressed their buttons and there is probably a fire somewhere. | |
| What's the difference between a 'flat' and an apartment? Anyway, isn't there some resistance with a long run of wire? At the time in my education, I thought it trivial... but think its several ohms per hundred feet (or was that meters). Anyway, with the wire run and component tolerance, quite a job calibrating for 120 units. Personally, I'd go with a phone line and an answering machine. Don't need someone to monitor the LED panel, and you get some description of why you are being summoned, and can deal with high priority problems first. | |
The wire resistance is almost constant and can be subtracted out. I've used a variation on this method. It works. | ||
| A PIC is overkill for this simple circuit! Hint: Flip Flop Switch, Dual Inverter Switch | |
So if instead you can have one pair from each group of flats to the panel, then you've reduced the wiring by quite a lot. Now sure you could do the same sort of arrangement in each group by using a few discrete components instead, but then how easily can you transmit the data of who in that block pressed their button, to the main panel? With a PIC you can convert this into serial data to go to the panel. Hell, you could even have just one pair of wires connect to the panel and attach the PICs to it in a bus configuration, although that's getting to somewhat more complex programming. It does have a conspicuous problem though, yes: he'd have to be able to obtain and program PICs You do also need a little extra electronics in the main panel to decode all this serial data, and note that one PIC alone wouldn't be able to handle 120 LEDs directly... | ||
| thnk u very much for ur suggestions i really appreciate it. . .. as i am nopt very good with PIC.so wat i hav in my mind is that conenct a group of 16 flats to a single multiplexer and then decode the signal using a D-MUX at the control panel . . .the problem in this circuit is that wat will happen if two flats simultaneously turns there switch on. . | |
wat will happen if 2 flats will turn there switch ON at the same point of time. . | ||
| Because of the way the resistors are specced you should always be able to tell which flat(s) have pressed the button - even if they all press their buttons you can still work it out via the resistance. For example on the above - with no buttons pressed (i.e. all closed) then you will have 0 ohms (actually you will have the nominal resistance of the wire). If all switches are on (open) then you'll have 500+1000+2000+4000+8000 = 15500 ohms resistance across the loop. If flat 5 turns theirs off then its 15500-8000 ohms = 7500 ohms Have a play with the maths and you will see what I mean. | |
like flat1=1000 flat2=2000 flat3=4000 flat4=5000 flat5=6000 if flat2 and flat3 will turn on then it will give 6000 ohms then there will be an ambiguity that might b flat 6 has turned on. isn't it? i | ||
| It seems to me that cabling-up all those rooms just to have a very basic signaling system may be not cost effective in the long term. Why not just install a data network and also provide an IP phone in each room. Perhaps you could then recover some of the installation costs by charging the residents for internet and phone service. | |
http://www.mediafire.com/imageview.p...yz3dh0&thumb=4 making group of 16 flats using single mux for eah grp. . but the problem now is that wat happen when 2 flats simultaneously turn the switch on. . pls help | ||
| That circuit is great if only one person turns on their switch but as you say - what if 2 or more do. Other than getting rather complex with the multiplexing and reading the values in with a microcontroller my idea with the resistors would be far easier. For someone who has experience in PIC programming its only about a days worth of work to knock up a working prototype and sort out the programming. | |
| Variable capacitor circuits | walters | General Electronics Chat | 83 | 11th March 2008 03:59 PM |
| 100 electronic circuits with ready to copy pcb | reyarba | Electronic Projects Design/Ideas/Reviews | 0 | 1st November 2006 12:32 AM |
| Directory of circuits | Circuit Seeker | General Electronics Chat | 2 | 6th April 2005 12:56 PM |
| Problem with 433.92 fm transmtter & receiver circuits | james120479 | Electronic Projects Design/Ideas/Reviews | 9 | 17th May 2004 02:08 AM |
| develop of pulse detection circuits for UWB radio... | blue boy | Electronic Projects Design/Ideas/Reviews | 0 | 9th March 2004 06:49 AM |
