Old 11th September 2007, 02:01 PM   (permalink)
Question Need a place to start...
I need to come up with a circuit to generate alternating currents. (Range 0-5A sinusoidal) It needs to be controlled through a user interface in the computer. I'm clueless guys. Plz help...
Give me a place where can start. I should admit that I'm a NOOB
Jester009 is offline
Old 12th September 2007, 03:14 AM   (permalink)
Anybody have any idea??
I have got three suggestions so far...
1). Using a triac with a PIC to control its firing angle...
2). Generate PWM and drive a half bridge with IGBT's...
3). Use an audio amplifier controlled by audio signal source...
I don't have an in-depth knowledge about any of these designs. Can anybody please comment on these... I'm kinda lost
Old 12th September 2007, 06:02 AM   (permalink)
Can you give us an idea of what frequency and voltage ranges you want in addition to the 0-5A capability?
This will give you a fixed output frequency and not a very nice sinewave at all.
This will do what you want, but is somewhat complicated for a noob.
This is will also work over a limited frequency range determined by the audio amp's frequency response.
You could use something like this with the audio amp:
http://www.freefunfiles.com/software...generator.html
kchriste is offline
Old 12th September 2007, 09:35 AM   (permalink)
Hi kchriste,
Thanks a lot for the reply. This is going to be used to test relays, i.e. apply a specified current and measure the tripping time. I don't have a clear idea about the voltage I have to generate a 50Hz sine wave of specified current ranging (0 - 5A)
I decided to take the amplifier option. So I guess the basic block diagram should be like this...
I still don't have an in-depth knowledge about the design.
I searched a bit and came up with a signal source. Hope I'll be able to use this...
http://wiredworld.tripod.com/tronics/signal_source.html
Please add comments... Will it be easy to follow the design with IGBT??
Old 12th September 2007, 10:02 AM   (permalink)
If its 50Hz and sinusoidal, why not use a Variac Transformer to drive a 1:1 isolation transformer [ thats if the isolation is required] ?
The voltage isnt specified, so taking the worst case as mains ie; 250Vac then
250 * 5 = 1.25KVA rating for both transformers.
You can get motorised Variacs that the PIC/driver can control.
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 12th September 2007, 08:39 PM   (permalink)
Yes I agree, but It's better to have the isolation transformer as at low voltages the current will be 'lost' magnetising the isolation transformer,
Screen name: Aloone_Jonez
Hero999 is offline
Remote Proximity Start mindctrl Electronic Projects Design/Ideas/Reviews 6 2nd October 2006 07:51 PM
CAPACITOR IN 110 1HP1PH MOTOR BLOWS SCMR2242 General Electronics Chat 3 30th January 2006 06:45 PM
Finding serial START bit by bit banging Oznog Micro Controllers 24 6th December 2005 10:20 PM
hardware or software fault? gastonanthony Micro Controllers 6 6th June 2005 02:13 PM
Help me start, making a servo controller for motorcycle use. motoracer General Electronics Chat 4 11th November 2003 11:29 PM
