Hi everybody!
for my friends in africa, I'd like to build circuit can converts 12V (car battery) continue to 220V alternatif (50 Hz). thanks |
I hate to discourage anyone, but if this were my call, I'd buy one. Building an inverter like that will probably cost more than buying one. And it's a relatively dangerous project, as such things go. Disclaimer: I'm a hobbyist, not an electrical engineer, so maybe somebody here has a more hopeful answer for you. I haven't seen much on the net to make me think this would be a good beginner's project, though. Good luck, whatever you decide! Torben |
Thanks for your reply torben!
But, I think it's possible to realize that, i already found someone using it for other application (less current). About design, 5A why? because, my friend uses lamps (every lamp has 75w), TV,radio and one refrigerator: domestic application someone has idea? |
Simple answer, BUY ONE - they are really exceptionally cheap these days, far cheaper than trying to make one.
However, your requirement for 1200W or so really calls for more than a 12V battery, and massive batteries at that, if you expect more than a few nmutes battery life?. |
Thanks for your reply guy,
I'm agree so, I want to know what circuit use to build this project, I already found in google, a lot of schema use boost convertissor, others use H bridge, but to calculate power and consumation thanks |
Power and consumption is dead easy to calculate - you want 5A at 220V, that's 5 x 220 = 1100W. Assuming 80% efficiency, that's 1375W drawn from the battery. So at 12V it will consume roughly 115 Amps, a 24V version would draw 57.5 Amps. Assuming your 12V battery is off a car, and possibly 50AH? - which gives an estimated 2 minutes battery life! - a 100AH battery would give you 4 minutes!. |
Ok guy!
but, i think to realize this schema, i just replace the transfo, 12/220v, http://www.hiboox.com/lang-fr/image....g=3xycw0mp.gif about you, it consumes what? |
excuse me
the first schema is wrong, the true is: http://www.hiboox.com/lang-fr/image....g=u25lg0bj.gif |
You should look at the entire project on the Japanese guy's website to see how weak his inverters are.
The first one is shown to drop its ouput voltage when the load is only 10W and has a max battery current of 3A which is 36W. The second one has an output voltage of 110V without a load, 100V with a 40W load and 90V with a 140W load. http://hobby_elec.piclist.com/e_ckt30.htm Many electronic devices don't work from a square-wave. Some radios and TVs, some computers and most electric motor speed controls don't work. Light dimmers might blow up.
Uncle $crooge |
Use compact fluroscent lamps, they use 1/5th of the power so you can design your inverter to output just 1A and save yourself a lot of bother.
Even better, just buy 12V compact fluroscent lamps, the you don't even need to bother with the inverter.
thanks for your reply
thanks ! |
The output impedance of a powerful inverter is too low for an LC filter to work.
Even if the harmonics of a square-wave are removed, the fundamental frequency's voltage is 0.707 times too low. The harmonics are half of the power from the inverter.
Uncle $crooge |
ok thanks! now i understand,
to have 24V in input (Two battery) or others methods? thanks! |
5A at 220V is 1100W and the inverter will heat with about 220W so the 24V battery will have a current of 55A. Two big car batteries will power it for a little over 1 hour.
A square-wave inverter is simple but many loads won't operate properly. A modified sine-wave is complicated. A true sine-wave is a very complicated circuit.
Uncle $crooge |
