Old 10th September 2007, 11:38 PM   (permalink)
Default 24VDC to 12VDC using LM317T questions
I need to reduce 24VDC to 12VDC. The load draws <.6 amps @ 12VDC. The LM 317T is supposed to handle up to 1.5A. I made the simple circuit with a couple resistors and have the desired voltage in/out voltage but the LM317 is getting too hot still even with a heat sink on it. I reduced the load to about .319 amps and it still gets hot. Is this because I am dropping the voltage so much? Is there any way I can keep the temperature down by reconfiguring the circuit? Possibly different value resistors in different spots? Below is a diagram of what I put together, R2 is 1.2K ohms, and R1 is 135 ohms. If I put a higher resistance on R1 and drop R2 would that make any difference? I know I can achieve the desired output voltage with various configurations but would like some input.
Any tricks to parallel two or more LM317's together to get more current capability? Also, if anyone has another way to drop 24v to 12v reliably feel free to post it. I'd like to keep it simple and inexpensive. What I'm doing is adding a small neon transformer/lights made for PC's to an industrial control panel with a build in 24V power supply. I use them in some other panels I make that can use 12v throughout but I have some where the primary voltage requirement is 24v and I don't want to have to add another power supply.
qsiguy is offline
Old 11th September 2007, 12:19 AM   (permalink)
The LM317 has 12V across it and up to 0.5A through it.
Simple arithmatic calculates 6W of heat. Not much.
A black aluminum finned heatsink isn't huge if thermal grease is used and the heatsink is in free air or has a fan.
But if the "heatsink" is just a piece of tin can and is inside a box then it won't cool the regulator.
audioguru is offline
Old 11th September 2007, 01:04 AM   (permalink)
I'll have to check the actual current on the output. The current tests were done on a 12volt supply without the regulator being used to determine what was required. When I run the Neon light with only one bulb (can use 2) the amperage was only .319 straight from a 12v supply. When I have it running through the regulator with a 24v supply, dropped to 12volts into the neon running one bulb the LM317 gets too hot for me to keep my fingers on it. For a temp heat sink I have 4 - 1" diameter washers bolted to it and they all get quite hot. I'm sure a finned heat sink will be better but it gets "too hot to handle" in less than 1 min. of operation so I am doubtful that a different heatsink will make that much difference with the exception of a really large one.
qsiguy is offline
Old 11th September 2007, 01:17 AM   (permalink)
A heatsink is aluminum with fins to transfer the heat to the air.
You don't have a heatsink, you just have a bunch of washers
Get a real heatsink to cool the regulator..
Old 11th September 2007, 01:26 AM   (permalink)
lol, ok. Did some actual output readings. 12V/3.77W/.318A as measured with a digital power analyzer in series with the output. Temp got up to 147*F after about 2 min.......I'll pick up a proper heat sink before my next bench test. I'm sure I have a few laying around, just have to find one.
Thanks for the input. BTW, is this the best/simplest way to accomplish my goal? Seems like it but want to make sure there isn't a better way. Assuming the proper heat sink does the job I doubt I could make it work for less $$ but if there is a more reliable way to do it a cheap price isn't the main determining factor for this. I do have some leeway on the budget. Any comments?
qsiguy is offline
Old 11th September 2007, 02:13 AM   (permalink)
The 12V regulator needs an input voltage of at least 14.5V. Your input voltage is too high and causes too much heat in the regulator.
You could add a power resistor in series with the regulator to drop 9V (28.3 ohms, use 27 ohms) so the resistor will dissipate 2.9W and the regulator will dissipate 1W without a heatsink. If it is in a TO-220 case then its max allowed dissipation without a heatsink is 2W.
Old 11th September 2007, 02:55 AM   (permalink)
To avoid the heat, you need a switching regulator.
A very simple one:
http://www.romanblack.com/smps/a04.htm
To keep it even simpler use a R-7812-0.5
Or a:
http://focus.ti.com/lit/ds/slts013/slts013.pdf
kchriste is offline
Old 11th September 2007, 07:26 AM   (permalink)
Here are 2 schematics with a LM317T in them, I hope this can help you in some way:
LM317T Voltage Regulator with Pass Transistor
LM317T Variable Voltage Regulator
Jospfh is offline
Old 11th September 2007, 06:33 PM   (permalink)
Did you check the degree C/W rating of your heatsink? It should be adequate to stop the die from exceeding the maximum rated temperature and shutting down.
Screen name: Aloone_Jonez
Hero999 is offline
Old 11th September 2007, 07:01 PM   (permalink)
So my original theory of too high input voltage creating the heat is the issue. I did get a proper heat sink and it still gets way too hot. kchriste, that part you suggested is actually a really good option. Off the shelf and ready to go. I actually did some checking and there is a replacement version of the that Mouser stocks. Here is the datasheet
http://focus.ti.com/lit/ds/symlink/pt78st212.pdf
At $24.45 from Mouser it's a great turnkey option for me.
As far as making my own circuit work, what if I stepped down the voltage gradually using 3 LM317's in series? Drop the voltage by 6 volts each step. 24->18->12. More parts but in theory that would also work, correct?
Jospfh, I've seen the diagram you link to. I don't quite understand how the regulator keeps the output voltage where it needs to be with a bypass transistor going around it. Can someone clarify this circuit.
qsiguy is offline
Old 11th September 2007, 07:11 PM   (permalink)
Have you measured both the input and output voltage?
If you're getting 12V on the output then I wouldn't worry about it.
What are you using it to power?
Have you considered upping the output voltage slightly?
If your device is designed to work from a lead acid battery then it should work from 13.8V with no trouble.
Hero999 is offline
Old 11th September 2007, 07:24 PM   (permalink)
hi
Does this help?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 11th September 2007, 09:00 PM   (permalink)
Power is from an IDEC 24VDC control panel power supply which is what will be used in the panel this regulator would be used in. I did try to take the voltage up to about 14 and it still got too hot. Somewhere I read to keep the voltage differential below 7 volts which would make my output 17 volts and I'm pretty sure that would fry my neon transformer.
Thanks for that explanation Eric, makes more sense now. So I assume that the capacitor on the output is much more critical in that circuit than it would be in a basic regulator circuit since there will be some oscillation?
What about the "daisy chain" option to get the voltage down or running two or three in parallel? Can the LM317 be ran in parallel?
qsiguy is offline
Old 12th September 2007, 01:46 AM   (permalink)
The problem is that the total heat will still be the same. ie: you'll need 3 heaksinks the same or bigger than the one you are already using so you are not getting anywhere. You are just spreading the heat around.
That'll work great and run a lot cooler than any linear regulator such as the LM317s.
kchriste is offline
Old 12th September 2007, 09:21 AM   (permalink)
You could, if there is no other more efficient way, use a dropper resistor in series with the +24Vdc and the LM317 input.
A rough calculation.
Drop from +24V to say, +15V [ leave 3V across the LM317]
To drop 9V at 0.6A, [9/0.6], requires a 15R resistor, watts = 9V * 0.6A = 5.4W, [use a 10Watt] resistor.
So dissipation across the LM317 3V * 0.6A = 1.8Watts.
A small heatsink would keep the LM317 happy.
I would choose to take some turns off the transformer secondary winding, if thats possible..
so you get about +16V from the FWB/smoothing that drives the LM317
Eric
PIC tutorials:
I need a 1000W 12VDC - 240VAC inverter ebuka_2 Electronic Projects Design/Ideas/Reviews 13 15th October 2008 12:41 PM
12Vdc -> +-12Vdc bh00 General Electronics Chat 9 12th August 2007 10:33 PM
Electric Heater and FeCl3 Questions: Lots of em DigiTan General Electronics Chat 13 3rd January 2006 08:46 AM
Beginner Questions: AC, Impedence, Transistors, and Salving budidharma General Electronics Chat 5 9th December 2004 09:43 PM
Electronics Pre-Test questions Mike_07 General Electronics Chat 0 13th November 2003 03:22 AM
