| Which is more suitable? In my circuit, I have a PIC 12F675 acting as a 2.5hr timer(running thru delay), and when the (delay)/timer has run out, the pin GPIO2 goes low. But during the time that the pin is high(2.5hr), I have 24 vdc going to a set of batteries, thru a relay, or a transistor. No more then 2 amps. Which would be more efficient? The relay or the transistor? You must of figured out already, that the PIC is running the relay or transistor. I hope this is clear enough. | |
| Depends entirely on what you're trying to do?, you don't give enough information!. | |
| Hey Nigel, think of it as the PIC gives a signal (high) to either a relay or transistor to keep a valve open. The valve is held open until the timer runs out. What I want to know is which uses the least amount of power to actuate the valve, The relay, or the transistor. Thanks | |
| For 2A you could use a TIP31A transistor. At a collector current of 2A its base current should be 200mA but it will work (not good) if the base current is only 100mA. A 2A relay needs a coil current of about 40mA at 12V. A Mosfet doesn't need any current to turn it on very well.
| OK Audio, It's what I thought, but again just double checking to make sure. I thought for sure a Darlington transistor would use less energy to keep the flow of current going from collector to emitter, instead of a relay mechanically latched and held that way to do the same thing. I guess a Mosfet can also do. Just needed to be clear on this, as relays are expensive. Thanxs | |
| Use either a darlington transistor or a logic-level Mosfet.
| Ok Thanks Audioguru, I appreciate the help. | |
| If you want really low power use a latching relay. | |
| I see what you mean blueroom, but trying to keep cost low as possible. I will go with Darlington, and see what gives. Thanks for input. | |
| Depending on what you're switching the relay might be the cheapest option. Why does it have to be cheap? How cheap under $10? | |
| Yes under $10. I checked Digikey, and cheapest was $15 from OMRON(Latch Relay). The whole board has to be under $10. A PIC, a Darlington and a few resistors and caps, and that's it. I should acheive that no problem with a darlington transistor. I hate these budget projects from the company I work for. Anyways, Thanks. | |
| The IRLZ34NPBF-ND FET at DigiKey costs $2.12 CDN and will switch up to 30 Amps. It has a max RDS on of 0.06
__________________ --- The days of the digital watch are numbered. --- Last edited by kchriste; 11th September 2007 at 05:58 AM. | |
| Need a relay controller | rtm038 | Electronic Projects Design/Ideas/Reviews | 14 | 18th November 2007 06:20 AM |
| Turn 'off' a relay using alarm clock...(help) | bd13 | Electronic Projects Design/Ideas/Reviews | 3 | 1st September 2004 01:02 AM |
| Relay Connections | Johnson777717 | General Electronics Chat | 2 | 7th July 2004 10:45 PM |
| MCU controlling relay (or a way to simulate a SPDT relay?) | LiquidKernel | Electronic Projects Design/Ideas/Reviews | 5 | 25th March 2004 04:10 PM |
| Incubator Relay Circuit | Plip | Electronic Projects Design/Ideas/Reviews | 2 | 26th November 2003 01:36 PM |
