Old 10th September 2007, 05:06 PM   (permalink)
Default Need Help In This Circuit !
Hi all,
I have come up with my own flowchart [attached here] for my circuit.Since I'm newbie to electronics , i don't know what to use to do my circuit.Please help me !
I'm using DC motor.And I'm not cared about PWM and load etc..i just need to rotate my motor.
Please help me with circuit diagram !
Thanks .
flemmard is offline
Old 10th September 2007, 05:33 PM   (permalink)
hi Again!..
From your flow chart it appears that you want to drive a motor clockwise for 5secs, stop, then drive the motor counter clockwise for 5secs. stop. is that right?
Is the motor a simple dc reversable motor or a stepper motor?
Whats the power requirement of the motor Volts/Amps etc..?
Is it driving anything?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is online now
Old 10th September 2007, 05:38 PM   (permalink)
Originally Posted by ericgibbs
hi Again!..
You are exactly right !
And I'm using a simple DC reversable motor.
The voltage from PIC is 5v to drive the motor.
I wish to make a sliding door using this concept.Just a sliding door model.
I need more power for that ? A gentle sliding would be fine.
Thanks !
flemmard is offline
Old 10th September 2007, 05:47 PM   (permalink)
Thanks !
You dont need a PIC for this.
Use two 555's connected as monostables.
Trigger MS1 for 5secs fwd drive, at the end of the 5sec, it trigger the second MS2 and a 'H' bridge motor drive for rev for 5secs.
Does this help?
Eric
PIC tutorials:
Old 10th September 2007, 05:50 PM   (permalink)
Does this help?
I need to drive my output signal from PIC to activate this motor circuit.
Can you please elaborate more now?
flemmard is offline
Old 10th September 2007, 06:03 PM   (permalink)
Have you decided which PIC you are going to use and are able to write a PIC program?
Look at the attached pdf for idea's, you can replace the two relays with transistors if you wish.
The simple 'H' bridge as shown, using relays, is fool proof.
The trigger could come from your PIC or you could use two PIC pins, one for fwd one for rev.
Eric
PIC tutorials:
Old 10th September 2007, 06:12 PM   (permalink)
They are right you just need a 555/556 timer chip(s).
http://www.kpsec.freeuk.com/555timer.htm or
http://home.cogeco.ca/~rpaisley4/LM555.html
But if still want to use a PIC chip look at this site
http://f-cpu.seul.org/~nico/astromec...rick_motor.pdf or
http://www.mcmanis.com/chuck/Robotic...cts/servo.html
Do not forget to "GOOGLE" and if you do not find what you are look for just change the words around>
BEN
ben1son1 is offline
Old 10th September 2007, 06:24 PM   (permalink)
Hi Eric,
Thanks for your great help ! I'm coding my logic in PIC16f877.
I'm using Hitech C PIC compiler.
After my programming, I will post it here.if I have doubts , please help me !
Btw, i can use delay_ function inside PIC for 5 sec activation rite? then why should i need 555 timer?
flemmard is offline
Old 10th September 2007, 06:31 PM   (permalink)
Thats right, no 555's required, good luck with your project.
Eric
PIC tutorials:
I need help in designing a circuit chefach Electronic Projects Design/Ideas/Reviews 13 27th September 2007 12:15 PM
power electronics circuit analysis ptewright Electronic Projects Design/Ideas/Reviews 2 25th November 2006 09:17 AM
Circuit auto OFF feature after no events design Uman Electronic Projects Design/Ideas/Reviews 2 3rd May 2004 06:34 AM
HELP! a digital signal to close a circuit fireismyflag Electronic Projects Design/Ideas/Reviews 2 22nd March 2004 11:46 PM
Circuit functioning very strange. Why? Cyclone Electronic Projects Design/Ideas/Reviews 12 4th November 2003 01:31 AM
