| can anyone tell me how to make a electric fence energiser that would send pulses a long distance and run of a 12v battery links to diagrams and stuff would be most appreciated cheers | |
| What voltage are you looking for? Is this a cattle fence? What wattage? what amperage? We need a bit more info to get started. | |
| its for horses i know nothing about electric really i think it should be about 15000 volt output pulse every second or 2 ive no idea about wattage.i know you can use a car ignition coil and transistors and a timer of some sort but dont know what i need to construct it to get the output voltage. Last edited by tkaraven; 9th September 2007 at 09:56 PM. | |
| 15kV is way way too much for a horse fence. I would have a voltage of about 1kV AT MOST. I think a microwave transformer would work. DO NOT OPEN A MICROWAVE EVER!!! | |
| You definitly don't know what you're doing. Buy a commercial electric fence generator. Two seconds on google and I found http://www.electric-horse-fence.com/ It's not as simple as just slapping a generator on an existing wire fence either. Insulators have to be mounted on the wire to the wood as damp wood is a pretty good conductor of electricity at high voltages. A generator sufficient to 'warn' animals at the most distance portions of the fence will kill animals closer to the generator if proper insulation isn't used, that or the far ends won't give enough voltage for the animals to notice.
__________________ "Because I be what I be. I would tell you what you want to know if I could, mum, but I be a cat, and no cat anywhere ever gave anyone a straight answer, har har." Last edited by Sceadwian; 10th September 2007 at 06:15 AM. | |
Search this forum for 'electric fences', there's lots. eg: http://www.electro-tech-online.com/e...electric+fence I would advise you start with a voltage of far less than 15Kv, start about 1KV and slowly increase it until get a reaction/response from the horses. They will get the idea very quickly and avoid the fence. Place red or yellow marker tapes on the wire fence so that the horses can associate the marker with a shock and keep away.
| a friend of mine will be building the project i just need schematics and instructions on how to do it could do with the output being about 3joules pulse this will travel about 3km. the friend of mine is an electrician and repairs fruit machines hes had a try with a transformer out of a fruit machine transformer it gives a shock but its a comfortable one that tickles more than anything the out put voltage i put earlier was a misprint i meant 1.5kv could use upto 5kv the higher the better ive bought a cheap energiser but it doesnt bother the horse its only low output so if some one can help me id appreciate it. | |
| ive no intention plugging into mains as i have no mains were my horse is its rural out in the sticks thanks for advise on phsyco electrician lol | |
| There is good information at: http://safefence.com/EF_Theory.htm They suggest 2000 volts. I know grounding is very important. You must limit the current! Send a pulse then no voltage for a second or two. I once grabbed a fence that had high voltage with no break. It was very difficult to let go. In this area there is a law that the fence must be off for a second to allow people to get off the fence. Also you must have a small sign indicating electric fence. I live in a rural area and many of us have electric fences with out signs but if people are around you should put up a sign. | |
| If your fence kills people then you could get done for manslaughter, I would really recommend that you buy it if you don't know what you're doiung it could be dangerous.
| has to be a continuos flow of ac current to kill someone the fencer pulses for one ns every 1 or 2 seconds | |
Oh yeah back on topic... The most amount of voltage I have "experimented" with was 330 from a disposable camera, so dont listen to anything I say that has anything that uses voltage above 12V. BUWHHAAHAHAHA! | ||
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
| radio fence and RF sheilding | justDIY | General Electronics Chat | 13 | 23rd September 2006 11:54 PM |
| Electronic fence lock actuator | Oznog | Electronic Projects Design/Ideas/Reviews | 4 | 28th March 2006 06:46 AM |
| Electric fence | zachtheterrible | General Electronics Chat | 6 | 15th June 2005 05:33 PM |
| Electric fence doesn't work? | teslatower | General Electronics Chat | 46 | 3rd June 2005 06:31 PM |
| Electric fence tester. | KOEZE | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2003 08:04 AM |
