| You could probably use a capacitive discharge ( .47 uF ceramic ) through an ignition coil with a relay / 555 timer if you want something cheap and dirty, Try keep the pulse rate repitition rate between 1 and .5 hZ and *NEVER* connect directly to any mains. A microwave transformer *WILL* be deadly ! high voltage and high current ! You should never experiment with high voltage unless you know what you are doing. | |
| You might consider using this circuit. It uses a 12 volt car ignition coil and works very well. http://www3.telus.net/chemelec/Proje...cer/Fencer.htm The reason you NEED a High Voltage is so it can Penitrate the Fur on the animal. 1000 volts is not enough to do that on a horse or cattle. And it Isn't the High Voltage that is Dangerous, its the Current and the Length of ON TIME that needs your consideration. Gary
__________________ I No Longer accept Private Messages on here. All Emails to me Must Contain the Word \"Electronic\" in the \"Subject Line\" or they go Directly to my Junk Mail Folder. Email me at: chemelec@hotmail.com Website: http://www3.telus.net/chemelec | |
| radio fence and RF sheilding | justDIY | General Electronics Chat | 13 | 23rd September 2006 11:54 PM |
| Electronic fence lock actuator | Oznog | Electronic Projects Design/Ideas/Reviews | 4 | 28th March 2006 06:46 AM |
| Electric fence | zachtheterrible | General Electronics Chat | 6 | 15th June 2005 05:33 PM |
| Electric fence doesn't work? | teslatower | General Electronics Chat | 46 | 3rd June 2005 06:31 PM |
| Electric fence tester. | KOEZE | Electronic Projects Design/Ideas/Reviews | 10 | 30th September 2003 08:04 AM |
