Old 6th September 2007, 07:12 AM   (permalink)
Question Current Injection Circuit
I am required to come up with a current injection circuit. The circuit would output user defined currents(preferably use a microcontroller for this purpose) I'm looking for a range of 0A-12A.
Please any input is deeply appreciated, I'm clueless here
Jester009
Jester009 is offline
Old 6th September 2007, 11:31 AM   (permalink)
What is the current being injected into?
What voltage range?
Super_voip is offline
Old 6th September 2007, 11:41 AM   (permalink)
Hi Super,
Thanks for the reply. This is part of a project I am assigned. If I describe the whole scenario, this is what happens...
The user selects the level of current from an interface in the computer. Then the computer communicates wit a circuit and that specified current is injected from the circuit into a relay. The tripping time is sent back to the computer.
I'm talking about the circuit which output that specified current to the relay. Hope I made it clear enough. Current have to be controlled within 0 - 12A
Jester009
Old 6th September 2007, 11:52 AM   (permalink)
So a circuit breaker tester, there would appear to be 3 parts to this
1. Generate the current
2. read the current
3. read the time delay in tripping the breaker
Old 6th September 2007, 12:21 PM   (permalink)
Yes, Can you shed any light on 'how to generate the current'
I have to complete the project within this month and I have no idea where to start
Old 6th September 2007, 06:05 PM   (permalink)
Is the current 'Alternating' or 'Direct'
specie is offline
Old 7th September 2007, 10:56 AM   (permalink)
Doesn't matter, circuit breakers will work with either, as for the current try relays switching at, say, 1 Amp levels and transistor-fet to supply at lower levels. So have a bank of relays directing the voltage source through a resistor which will keep the current to desired level to a paralleled output.
A careful selection of currents via the relays will reduce the amount of relays needed eg 1,2,4,5 Amps will give you 0-12Amps in 1 Amp steps except 8amps,so you can see 12 relays aren't needed. The transistor supply will need to be able to supply 0-1A.
Old 7th September 2007, 11:38 AM   (permalink)
Originally Posted by Super_voip
A careful selection of currents via the relays will reduce the amount of relays needed eg 1,2,4,5 Amps will give you 0-12Amps in 1 Amp steps except 8amps.
I think you need to check your binary maths?
1, 2, 4 and 8 amps would make more sense, and give 1A steps from 0 to 15 amps. Even with the 5A you suggested, 8A is simple 5+2+1.
Old 7th September 2007, 11:42 AM   (permalink)
I wasn't going to work it out for him/her, and I'm tired
Old 7th September 2007, 01:05 PM   (permalink)
What about Thyristors or triacs?
specie is offline
Old 7th September 2007, 01:12 PM   (permalink)
I have to inject an AC current ranging from 0-5A. Triacs or Thyrisotors do not produce pure sinusoidal waveforms. do they?
Old 14th September 2007, 08:48 AM   (permalink)
Neither do relays. They are to be used instead of relays
specie is offline
Magnets and Electromagnets ElectroMaster Electronic Theory 11 27th November 2007 03:31 PM
Current and Conductivity ElectroMaster Electronic Theory 1 2nd February 2007 01:50 PM
Discrete Pulse width Modulator... Rajagopal87 General Electronics Chat 8 16th August 2006 06:25 AM
high current power supply circuit. Bondfire General Electronics Chat 18 18th April 2005 08:07 PM
Current detector circuit fuzzy Electronic Projects Design/Ideas/Reviews 1 14th October 2003 01:03 PM
