| Hi all, Apologies in advance is this may seem a naive question, or if it has been covered before. I am a Physical Chemist, working at a Uni in Australia, and I need to have some voltage supplies for electrostatic lenses of a mass spectrometer. The supplies need to be bipolar, and be tunable from -100V to 100V out of the one channel (i.e. not unplugging the leads). In all I need four independent supplies. The current would be very low, as the electrostatic lenses are isolated from ground. A group I worked with in Germany had six electronics gurus who made these things, however here I have not much support! What I am looking for is an answer to the question, can these be made easily? Does anyone have an idea on how this can be done? I would really appreciate your help! | |
| By the way, I said that I was a Physical Chemist to highlight the fact that I am a simpleton when it comes to electronics! | |
| Can you get the circuit diagram from the previous electronics guys?, as it's a proven working design it seems silly to reinvent the wheel?. | |
| Hi Nigel, thanks for getting back to me. Unfortunately, they are not being very forthcoming with the schematics. I have asked a few times, and been fobbed off. I will ask again, however I am not hopeful! Just wanted to see if anyone had an idea of how to do it, as I am challenged when it comes to these things. | |
| G'day specie, Thanks for your post! Here I will show my lack of knowledge... As the plates that I wish to apply the voltage to are isolated from ground, am I right in thinking that the only current flow will be due to the slight capacitance that the plates will have? By this I mean that the current will flow only during the initial charging of the plates? I have not calculated the capacitance, however I have a journal article that has some equations for doing this for different plate shapes etc (i.e. whether they are circular, rectangular, etc) Yuanshun Chi, European Journal of Physics, volume 17 pages 363-364 For a different application, with bigger plates than the ones I plan to use here, I calculated a capacitance of 5.5 pico Farad. From this, I would imagine that the current flow would be negligible. Cheers! Last edited by DrDunk; 7th September 2007 at 02:51 AM. | |
| G'day again, Apologies for the next "stupid" question, however can I get a feeling from you all of what is considered to be a "low current"? My thinking would be that 500ľA or below would be a low current, am I right? Cheers! | |
| G'day Roff, Thanks for your reply. By temperature stability, do you mean the stability of the voltage output with respect to environmental temperature (i.e. of the lab), or the stability of the components? I would think that as long as the voltage did not change by 0.1% over the day, then this would be fine. Cheers! | |
| The lab is air conditioned, and will not change much throughout the day. What would you consider stable? +/- 5 degs? | |
| Yep I do (have 220V), and how much does the unit you produce cost?? (Apologies if this appears cheeky..) Last edited by DrDunk; 7th September 2007 at 06:46 AM. | |
No, I don't produce anything. I just have a fairly simple design that might work. I have it designed, but I need to do a little research on components before I post it, and unfortunately it's past my bed time. I'll get back to it some time tomorrow. | ||
| Hey DrDunk, You do not come across as a complete ignorant in electronics | |
| Expert Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 08:16 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 06:35 PM |
| switching high voltage supply | JPI | Electronic Projects Design/Ideas/Reviews | 6 | 4th May 2007 04:45 PM |
| amplification dependency on supply voltage | Othello | General Electronics Chat | 4 | 4th January 2007 05:56 AM |
| RE:- help!! AC switch mode supply for low voltage lighting | mikegaylor | Electronic Projects Design/Ideas/Reviews | 1 | 19th April 2003 03:10 PM |
