Thanks to both of you! I really appreciate the effort.
It will be great to have some circuit diagrams, as I have a couple of 3rd year students who would love to give it a go building them. |
Do all of the channels need to be isolated from each other? If so it would be a pain as each power supply would need to be run from a separate isolation transformer, unless you can find a transformer with four separate 0-75V windings.
Yes, that's exactly what I meant.
I'm thinking you could use a 75V transformer and some sort of linear regulator with a push-pull output to give +-100V but I'll wait until Roff comes back before I have a go at sketching a design for you.
Dr. Dunk, if the lenses draw zero DC current, the solution should be relatively simple. If not, it seems like it gets complicated. Don't you have a specification on these lenses? |
No current draw would be simple, a potentiometer across a fixed +-100VDC supply, an LM317 could even provide regulation as long as the voltage drop didn't exceed 40V. 500ľA isn't much, I haven't bothered to calculate the error but I imagine that a 20k pot acrosss a +-100V supply drawing 10mA wouldn't give that much of an error at 500ľA.
I don't know where you can buy pots rated to 2W at 200V though. Failing that a DC coupled audio amplifier run from about +-105V would do except you'd have to increase the voltage rating of the transistors, decrease their current rating and increase all the resistor values proportionally.
Unfortunately I don't have specifications on the lenses, as they are home built. Check out the pictures I have attached. The first one is the assembly as it is being made, the second is the assembly "in situ" in the vacuum chamber. You are looking for the brass plates (four of them). Theoretically, the current flow should be zero, as they are insulated from ground by the ceramic insulators that you can see. The design has one threaded rod (Stainless steel) around which a continuous ceramic tube runs. They there are larger diameter ceramic spacers that hold the plates out in space. Cheers! P.S. For your information, the other plates you can see are the Time Of Flight plates. They are an integral part of the mass spectrometer. Imagine a burst of ions entering the assembly between the second and third plates (moving directly into the photo). If you pulse a large negative voltage to the second plate in from the right, say -2 kV, and at the same time pulse a slightly less negative voltage to the third plate in, say -1.5kV, this leads to a potential difference of 500V, which serves to eject ions to the left, into the rest of the mass spectrometer! All of this assembly has been home built by our workshop gurus! I already have the fast high voltage switches (from a German company, Behlke) they are MOSFET style. Last edited by DrDunk; 9th September 2007 at 01:06 AM. |
If each of the brass plates is one terminal of a lens, where are the other terminal(s)?
Couldn't the flash unit from a disposable camera be utilised for this. These units produce around 300V and with some current limiting resistors and 4 51V zeners you would have a fairly stable supply.
Mike. |
What you do is connect the Vout of one terminal to the lens, while the other is grounded to the machine body. Effectively then, the circuit is not complete as the Vout is isolated from ground (hence the very low current flow). I will use BNC connections to a vacuum flange. the sheath of the BNC cabling will be terminated to ground (i.e. the flange body) Does this make sense? |
Try this out.
Good luck with finding an 80V transformer and a 20k pot rated to 2W though. Note that it isn't protected against short circuits, at least not for very long periods of time anyway, you can add a 10k series resistor in series with each regulator but it would have to be rated for at least 4W.
I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez Last edited by Hero999; 9th September 2007 at 07:35 PM. Reason: The negitive rectifier was backwards. |
Your negative rectifier is backwards.
Thanks Ron, err I mean Roff I've changed it.
The origional requirement was for 500ľA so I used 20k because it would give better regulation.
I don't know what the maximum value he can use without any trouble, it depends on the leakage current of the capacitance. He could try 100k or even 1M and probably won't have any problems, experimenting is the best way to tell.
| Expert Stabilised Power Supply with Current Limiting | mechie | Electronic Projects | 36 | 11th March 2008 07:16 PM |
| Voltage | ElectroMaster | Electronic Theory | 44 | 8th August 2007 05:35 PM |
| switching high voltage supply | JPI | Electronic Projects Design/Ideas/Reviews | 6 | 4th May 2007 03:45 PM |
| amplification dependency on supply voltage | Othello | General Electronics Chat | 4 | 4th January 2007 04:56 AM |
| RE:- help!! AC switch mode supply for low voltage lighting | mikegaylor | Electronic Projects Design/Ideas/Reviews | 1 | 19th April 2003 02:10 PM |
