Old 4th September 2007, 10:11 PM   (permalink)
Default More colors from normal leds???
I was working on a model train light circuit using leds and a curious thing happened. At one point, there was a short of some sort in the circuit and the green led was showing a distinct yellow indication.
I have not been able to duplicate the fault and was wondering if you can tell me how this might have happened.
I am also wondering what other colors might be extracted from so called normal colored leds, using a similar method.
Any help appreciated.
Greg.
gregted is offline
Old 4th September 2007, 10:25 PM   (permalink)
I'm guessing you were running too much current though the LED. I don't think much variation in color is possible using this method, and also, your LEDs won't last very long.
pc88 is offline
Old 4th September 2007, 10:29 PM   (permalink)
Green Leds usually run on voltage of about 1.7V. you might of accidently shorted out the resistor and the full voltage got through to it. Be careful and make sure you cover up your leads and wires on the reverse side. I put electrical tape on the back of my circuit boards to prevent just that. Whenever I dont put tape on it, It awlays shorts out somewhere, so be careful!
Krumlink is offline
Old 4th September 2007, 10:31 PM   (permalink)
If you want 3 colors then use an ordinary red-green LED.
If you want millions of colors then use an RGB LED or make your own with red, blue and green LEDs.
audioguru is online now
Old 4th September 2007, 10:39 PM   (permalink)
I prefer milky or hazed LEDs. If you get waterclear RGB LEDs you can see the Dies clearly and it kind of ruins the mixing color effect.
Krumlink is offline
Old 4th September 2007, 11:12 PM   (permalink)
Could be a "bicolor" LED. Green when current goes in one direction, red in the other, AC make red and green which blends into yellow in the human eye.
Oznog is offline
Old 5th September 2007, 12:24 AM   (permalink)
That yellow colour was the diode junction starting to act like a regular lightbulb. You can only do that a few times before you end up with a piece of useless plastic. LED's are capable of producing only a single colour of light.
straight answer, har har."
Sceadwian is offline
Old 5th September 2007, 01:10 AM   (permalink)
LED's do have tha ability to give a little spectral variation. The more energy through the LED, the higher frequency of light they give off. I don't know what the range is, but you can push more current through the junction and shorten the wavelength by more than 20 nM. Obviously, too much current and the LED dies.
The color change is exploited by chemists as a sensitive probe into some absorbance phenomina.
j.p.bill is offline
Old 5th September 2007, 06:01 AM   (permalink)
Its normal.When you give 2V it might light up with the colour it has green.But see after increasing the voltage to the green LED,it will change its colour to yellow.If you still continue giving more voltage than rated voltage you will see nothing from few minutes but you will feel a bad smell.
Super Green Mat LED is best for me.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 5th September 2007, 08:46 PM   (permalink)
I fed 36V at about 500ma (model train power supply, now dead ) into a LED real fast and it exploded into flames, sending flaming chunks of plastic everywhere. Ouch. It was pretty awesome though.
Krumlink is offline
Old 8th September 2007, 11:30 AM   (permalink)
What you're saying is true but that wasn't the case here as yellow is a longer wavelength than green.
I read somewhere that it's possible to get some blue LEDs to emit UV by pulsing them at very high currents but I've never tried it, I think you need a specific kind of blue LED.
Screen name: Aloone_Jonez
Hero999 is offline
RGB Leds, More than 7 colors. nuttaphong191 General Electronics Chat 10 5th July 2007 03:17 AM
Introduction to High Brightness LEDs and Thermal Management Ocelaris Electronic Projects Design/Ideas/Reviews 3 17th March 2007 06:35 AM
Problems with Dual Brightness (Current) LED Tail Lights? Eagle Schematics! Ocelaris Electronic Projects Design/Ideas/Reviews 12 31st December 2006 07:18 PM
A Basic Question of Efficiency - 4 LEDs in parallel or series!?! Agent M Electronic Projects Design/Ideas/Reviews 9 27th December 2006 04:23 PM
LEDs from the Far East. ThermalRunaway General Electronics Chat 12 15th August 2006 02:37 AM
