Old 2nd September 2007, 04:01 PM   (permalink)
Experienced Member
iONic is on a distinguished road
Default Solar Battery Charger suggestions Needed...
I am hoping to build a "Universal" Solar NiCd, NMH, and Lithium Ion Battery Charger to charge anything from a AAA Battery to a 12V/35HA Scooter Battery.
Thus I am looking for suggestions on the Solar capacity needed to charge the batteries in a reasonable amount of time. For example... to charge the scooter
battery in a couple of sunny days.
Circuit design ideas are also welcome!
Any reference material (websites) would also help.
iONic is offline   Reply With Quote
Old 2nd September 2007, 05:40 PM   (permalink)
Experienced Member
Sceadwian is just really niceSceadwian is just really niceSceadwian is just really nice
Send a message via AIM to Sceadwian Send a message via Yahoo to Sceadwian
There are several ways of approaching this. The solar cells are going to have to generate at least enough voltage to drive your control electronics and then you're going to have to use a switch mode converter to adjust the final output voltage to the charging voltage. 1.5 to 13 volts is a pretty wide supply range. It could be as simple as using enough solar cells to generate the charging voltage and making sure they can supply enough current to change the batteries, no circuitry needed, but that's not going to be universal. The amount of current you need to supply depends on the number and type of cells in the battery and the amp hour capacity of the pack. Lipoly's need a relatively intelligent charger so you should think about starting with a 5-12 volt solar array that can handle the current requirements. Micro controllers are going to be the easiest solution, as the circuitry required to intelligently charge a battery is a bit difficult to do purely from analog parts. Suggestions would be easier if you could supply more information like the normal use for the charger, their capacity and your experience.
Curiosity killed the cat; That's why they have nine lives.
Old 2nd September 2007, 05:49 PM   (permalink)
Experienced Member
ericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to beholdericgibbs is a splendid one to behold
If you just considered your 12V/35Ah battery, which you want to charge in 2 days.
Electrical charge conversion efficiency, say 70%, [48AHr required] this means that it would require 2amps charge for 24 hours.
Say 15V at 2amps for 24 hours of sunshine.
So if you get 12 hrs sunshine a day it would require 2amps * 2days *12hrs
This means that output of the solar panel 14/15V at 2amps = 30watts.
Eric
"Good enough is Perfect"
PIC tutorials:
Nigel's: www.winpicprog.co.uk/
Gramo's: www.digital-diy.net/
Old 2nd September 2007, 09:29 PM   (permalink)
Experienced Member
audioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to beholdaudioguru is a splendid one to behold
12 hours of STRONG sunlight per day? Where? Bermuda?
You are lucky to get strong sunlight for 2 hours per day. Then the other hours don't have much power.
Clouds? Then good-bye sunlight and good-bye charging.
Old 2nd September 2007, 09:59 PM   (permalink)
Experienced Member
Mind you that's charging the battery from completly empty. Not something one usually does. The solar arrays are supposed to constantly trickle charge the battery.
Old 2nd September 2007, 10:07 PM   (permalink)
Experienced Member
HarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to allHarveyH42 is a name known to all
2 hours? Not everyone lives in Canada, yet... Unless we have a huricane passing through, usually clear skys most of the day. Raining right now, but it was hot and sunny until about 5 o'clock.
Anyway, 12/35Ah is going to take a pretty good size panel, not exactly portable. Seems like a lot to pack into a single project, three different charging circuits crammed together.
HarveyH42 is offline   Reply With Quote
Old 2nd September 2007, 11:21 PM   (permalink)
Experienced Member
You are almost on the Equator when the sun is the most powerful. Not many people can stand the heat, the hurricanes and the crime. (I think the Cubans and Mexicans who sneaked in love it).
Florida has hot and cold alligators and some very nasty people.
Old 2nd September 2007, 11:48 PM   (permalink)
Moderator
Krumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of lightKrumlink is a glorious beacon of light
Send a message via Skype™ to Krumlink
solar panel charging is near impractical in michigan. There are less than 100 days of the year in michigan that has a clear sunny day.
Visit my website!
http://www.freewebs.com/electronic-hobbyist
Krumlink is online now   Reply With Quote
Old 2nd September 2007, 11:53 PM   (permalink)
Experienced Member
At least the alligators do knock over trash cans like your polar bears...
Old 3rd September 2007, 12:10 AM   (permalink)
Experienced Member
I have seen polar bears in Canada only at the zoo. Alligators are also there.
It is the racoons who knock over garbage cans.
The racoons know how to move a big heavy rock off a garbage can so they can make a huge mess.
Old 3rd September 2007, 09:07 PM   (permalink)
Experienced Member
dannix is on a distinguished road
This maybe of interest, It is what I made to charge a 12Ahr battery. Calculation provided to adjust parimiters
http://www.arsqrp.com/ars/pages/back...ext/N7CEE.html
dannix is offline   Reply With Quote
Solar Powered Battery Charger tydude Electronic Projects Design/Ideas/Reviews 7 18th March 2007 10:31 AM
Solar powered lead acid battery charger plus Inverter Raj Lalvani Electronic Projects Design/Ideas/Reviews 4 13th March 2007 06:12 PM
Solar battery charger with moving panel Hanford Electronic Projects Design/Ideas/Reviews 6 8th October 2006 01:38 PM
Solar Battery Charger Space Man General Electronics Chat 2 20th May 2004 12:15 PM
solar battery charger induction1 General Electronics Chat 4 22nd May 2003 06:57 PM
