Old 1st September 2007, 09:02 AM   (permalink)
Default ir detector does not work
well we just built an ir emitter circuit emitting a 38kHz signal. we r confident that works. however the ir detector shows either high or low (when i block the signal with my hand). why does it not show a 38k signal?
help would be apreciated
blackbunny is offline
Old 1st September 2007, 09:09 AM   (permalink)
Assuming you're using an IR receiver IC that's how it's supposed to work, it demodulates the incoming IR and 38KHz carriers, and outputs the original modulation.
However, they are designed for data, not a plain carrier, and using a plain carrier will drastically reduce range.
Old 1st September 2007, 09:36 AM   (permalink)
we have an ic (generating the signal) hooked up to ir emitter. the receiver is just a receiver hooked up to an ociliscope
Old 1st September 2007, 10:04 AM   (permalink)
Like I said, it's working exactly as expected then - if you want an AC output from the receiver you need to modulate the 38KHz in the transmitter - this will also massively improve range.
Old 1st September 2007, 10:05 AM   (permalink)
Is the ic generating the 38KHz carrier signal or is the ic modulating the 38KHz carrier and is the receiver just a detector.
That is, are the 38KHz TX and RX ready built modules or have you made them?
Do you have a diagram to post?
Eric
"Good enough is Perfect"
PIC tutorials:
Gramo's: www.digital-diy.net/
ericgibbs is offline
Old 1st September 2007, 12:33 PM   (permalink)
Smile
Very simple concept.. it's this property helps it to use i r as proximity detector...
See.. there are two separate parameters.. 1. range 2. ability to pass through an object (transparency..)...both are independent factors...
*1. first thing you should remember is: if you want to improve the range.. then you are to reduce the duty cycle to 10 %... ( but you dont want this...)...
*2. second thing you should remember is: i am sure ..the ir rays never pass through an opaque object... Sometimes your detector gives high and sometimes low...
Reason 1 : very simple ... light travels at speed of 3,00,000Kms / sec. and hence it might be reflected many times before it reaches detector..
Reason 2 : or your detector might be faulty...
I hope you have used 555 timer...
regards..
simran...
Simran..
8051 Specialist..
simrantogether is offline
Old 1st September 2007, 12:40 PM   (permalink)
Smile use this...
Use tsop 1738 as IR detector.. and that of a good quality from a german co. called VISHAY...
any help you need ask...
Simran..
8051 Specialist..
Old 5th September 2007, 06:32 AM   (permalink)
As Sir Nigel said, 38 kHz signal has to be modulated and and most IR receivers have a maximum of 600uS pulse width modulation, longer than this will not be received.
penoy_balut is offline
Will this work? MagnumForce General Electronics Chat 7 11th November 2007 01:12 PM
Music unit for at work Odysseas Electronic Projects Design/Ideas/Reviews 9 5th September 2006 10:48 PM
now how do these work? moody07747 Chit-Chat 6 17th April 2006 08:18 AM
why doesnt it work Emantra General Electronics Chat 4 20th September 2005 03:59 PM
frequency-voltage don't work with electronic ignition. Screech General Electronics Chat 7 16th March 2004 01:29 AM
