| New Member | I came across a machine the other day with a check station, this station is checking for continuity on a previously installed wiring harness. and I was wondering if there is another way of doing it. they seem to be just feeding +24vdc to one pin and waiting for it to come back to the PLC card on the other pin, this works but the operators have figured out how to short the pin to the frame of the machine which results in blowing the fuse or shorting the card. if I were to isolate a separate voltage supply say five volts and not ground it to the common ground then it should not short basically i think. |
| Experienced Member | Quote:
As the 'output end' of the wire in the cable harness is connected to the input of a PLC, isnt it possible to fit a current limiting resistor in the +24Vdc feeding the 'input end' of the wire? After all, you are only testing for continuity not a resistance value. Eric | |
Mike. | |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 27th August 2007 11:05 PM |
| design of a continuity tester | pc88 | Electronic Projects Design/Ideas/Reviews | 2 | 12th June 2007 04:25 PM |
| faulty digital components testing,checking | walters | General Electronics Chat | 5 | 22nd August 2005 07:10 PM |
| Building a test set. | Freezerburn | Electronic Projects Design/Ideas/Reviews | 2 | 3rd May 2005 01:15 PM |
| ya | mari_69 | Micro Controllers | 4 | 7th June 2004 01:29 PM |
