| i have circuit schematic with uses a 555 timer powered at 12V to operate a relay. I want to change the switch for my amp but this switch is rated @1A max so i cannot use directly because the amp draw almost 5 amps from mains, but if I use the circuit iìm a little confuse by the relay, i never worked with relays before. I see that relays are given in catalogs with voltage coil specification and contacts max current something like 12V/2A. My circuit is powered by a 12 VDC supply so relay coil must be 12V. Can it be higher voltage level, say 24V? On the other hand if contacts are 10 A rated current can i use mains live and neutral if relay is DPDT? I want to be sure before building this circuit, not to burn the whole project Tommorrow i'll post the schematic, it has also 2 LED's to indicate on/off status | |
| Relays have two parts, the coil part and the switch part. The coil part usually has a coil resistance, a voltage to turn on, and a current to turn on spec. That's what's needed to activate the coil. Don't go too high on current/voltage or you'll overheat/destroy the coil. If the voltage you supply is too low, it will fail to activate - don't get one that's not what you want. The contact part is rated just like any other switch. Don't exceed any of those parameters either. Also make sure you check AC/DC specs as well as motor specs, they're special cases that could cause more wear/damage to the contacts than normal. Typically DC and motor specs are much more pessimistic. So what you need is input coil 12V, 100mA or less (though a 555 probably can drive more, better to be safer), and contacts of 220VAC, 5A per contact/circuit or higher. Adding a bit more margin would be nice too. You can use a DPDT to switch both hot and neutral for more safety, if you want, just don't miswire. You could also use two DP contacts in parallel to provide more margin, too. | |
| Here is the diagram ![]() I have a DPDT, (just to hook both live and neutral) relay rated @ 12V coil / 10A but those 10A is for AC or DC? I can use to switch for AC current? It is not specified voltage contacts only current Last edited by adrianbodor; 28th August 2007 at 03:03 PM. | |
| if a voltage is not specified, likely it's a low voltage DC relay and you shouldn't use it. You may get arc-over as the dielectric in the relay if it's not strong enough to handle 220VAC. | |
| Do you have a part number for this relay? Who made it? Can you send a picture? | |
| Yes, here is the link, this relay i want to use, DPCO plug-in relay, coil is rated @12VDC and contacts @15A-220V, i think is a very good choice for schematic above, what do u think? If circuit is powered @ 12VDC also the relay must be rated @12VDC coil, right? Thx, for any help | |
| Where do you live? As there are different shops in different parts of the world and you haven't filled your location in we can't really help you. I would look in RS components or Farnell.
| I live in Romania, and first shop to buy from is Farnell, that link above is the online catalog from Farnell UK | |
| Button Debounce Coding help | Suraj143 | Micro Controllers | 25 | 4th August 2007 10:49 AM |
| Relay on/off switch Pls help | slpee | Electronic Projects Design/Ideas/Reviews | 2 | 27th July 2007 08:46 AM |
| PIC Switch Management Techniques | Mike, K8LH | Micro Controllers | 2 | 28th September 2006 01:33 PM |
| Defeating a Dimmer Switch | mikeb | Electronic Projects Design/Ideas/Reviews | 2 | 3rd August 2006 02:38 PM |
| How to configure this On/Off Switch with Bicolor LED?HELP ME | Stimulation | Electronic Projects Design/Ideas/Reviews | 10 | 23rd April 2003 05:55 AM |
