Old 27th August 2007, 12:22 PM   (permalink)
Default Cant get LM2917 working
Hi I'm in the middle of making a frequency to voltage converter. I have an incremental encoder hooked onto my DC motor which spins at a max no load speed of about 3500 RPM (about 58hz).
I'm using the 16 pin package of the LM2917 freq to voltage converter IC, the data sheet for it is below:
http://cache.national.com/ds/LM/LM2907.pdf
My circuit is below, exactly as it appears on a breadboard:
http://aycu20.webshots.com/image/257...5476756_rs.jpg
I pumped 15V to VCC and had the incoder pulsing slowly (motor was turning slow), and the chip just heated up like crazy. I had VCC=5V and Vout just gave me 5V, so in other words VCC=Vout. Did I wire something wrong here? I think I've wired it according to "Minimum component tachometer" figure on page 8 of the data sheet.
vuchris is offline
Old 27th August 2007, 09:58 PM   (permalink)
You will, or already have, burn out the internal zener if you put 15V across it. Read the datasheet, especially the part about USING ZENER REGULATED OPTIONS (LM2917).
The datasheet doesn't appear to characterize the part with Vcc<6V.
EDIT: Also read the section, CHOOSING R1 AND C1. I think C1=22pF is way too low.
Ron (aka Rube)
Roff is offline
Working with household mains cables (not flex) SimonW General Electronics Chat 4 1st February 2007 02:12 AM
Help with LM2917 Frequency to Voltage Converter crice Electronic Projects Design/Ideas/Reviews 10 14th August 2006 08:31 PM
faulty digital components testing,checking walters General Electronics Chat 5 22nd August 2005 08:10 PM
Telephone Remote control Circuit not working MEHLULI Electronic Projects Design/Ideas/Reviews 2 13th April 2005 08:37 AM
Working Summing Amplifier Simulation? petesmc General Electronics Chat 2 25th November 2003 08:02 AM
