+ Reply to Thread
Results 1 to 8 of 8
Thread: use low source to switch higher source??
  1. #1
    daaaaay Newbie
    Join Date
    Aug 2007
    Posts
    3
    Default use low source to switch higher source??
    Ok.
    My problem is that i have a source that is to small to move this motor that i have. My source is about .5 volts when low and about 4 volts when high. Is there a circuit that will allow my source of .4 - 4 volts to switch a voltage of about 10??
    im open to any options
    thank you
  2. #2
    j.p.bill Newbie
    Join Date
    Feb 2007
    Location
    Missouri
    Posts
    211
    A logic level FET like a VN10LP might be just the item.
  3. #3
    Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent Hero999 Excellent
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,983
    What current does the motor draw?
    I'd go for something like the IRL540A as pretty popular.
    if I know the answer.
  4. #4
    dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent dknguyen Excellent
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,027
    Yup. A logic level MOSFET (a transistor) is just what you need. Don't forget a schottky diode anti-parallel to the source-drain to protect the transistor from motor inductive flyback (voltage spikes from switching something inductive like a motor), especially if your motor draws higher currents and you are switching it on and off frequently/quickly.
  5. #5
    daaaaay Newbie
    Join Date
    Aug 2007
    Posts
    3
    ok that makes scince to use the transistor but i am not sure how to get the secondary source to the motor. the computer is connected to the base, source connected to collector, and emitter is the output to the motor?? i would still get the voltage from the comptuer. i am not sure on the circuit
    i am using a TIP31C as i dont have many electronics stores in my area
    thank you
  6. #6
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,027
    One terminal of the motor is connected to the COLLECTOR and the EMITTER is connected to ground. The other terminal of the motor is connected to +V.
    YOu will need a resistor between the computer and the BASE since this is a BJT transistor of the NPN type and not a MOSFET. Also, remember that the BJT will drop 0.7V since this is a BJT and not a MOSFET.
    YOu also need the diode I was speaking about especially since this is a BJT and not a MOSFET (a MOSFET has a bad anti-parallel diode built into it which lets you sometimes get away without using an external one, but a BJT does not so you definately need one).
  7. #7
    Join Date
    Apr 2006
    Location
    England
    Posts
    12,983
    You still haven't answered the important question?
    The base current needs to be 1/10 of the motor current which your source might not be able to supply.
  8. #8
    Join Date
    May 2006
    Location
    Alberta, Canada
    Posts
    6,027
    Private Message From the OP indicates the motor is a stepper motor.
    Quote Originally Posted by daaaaay
    Thank you for all the help so far. but i am still having problems with this project. i did what you said and it worked but now that i am programing it. when i send a high to the base of the transistors in order it does weird things. like does small steps and moves backwards. I can manually do it by taking one of the inputs and touching the resistor and it works perfect. do u have any idea?
    So yeah, you are going to need a more complicated setup with more transistors for each winding of the stepper motor (you will also need to find how what wire is what on the stepper motor). We had assumed you were using a DC motor where you just apply power to the two terminals and it spins. In a stepper motor you have to manually select which windings are being energized to make it move forward, otherwise it will move to the winding energized...and just hold there. Google stepper motors to understand how they work.
+ Reply to Thread
  1. Touch Sensitive Switch (Take 2)
    By MonkeyMera in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th February 2010, 09:38 AM
  2. Earth Stator Motor
    By Gavilan in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th April 2005, 09:06 PM
  3. Crazy Resonance Problem
    By cchalmers in forum General Electronics Chat
    Latest: 14th February 2005, 03:47 PM
  4. Stuck in programming
    By vxr in forum Micro Controllers
    Latest: 23rd September 2003, 04:26 PM
Tags for this Thread
