Old 26th August 2007, 12:38 AM   (permalink)
Default 0.5Watt LED Driver
Most high power LEDs are run off constant current drivers, but is this really needed ?
Can a 0.5Watt LED be run using a normal safety resistor as long as the resistor is rated high enough and the LED has a heatsink ?
Are the only reasons these LEDs are run off constant current drivers because of varying input voltages and for efficiency ?
Thanks.
yngndrw is offline
Old 26th August 2007, 01:52 AM   (permalink)
LEDs are rated for current. Their forward voltage is a wide range of voltages so you must measure the forward voltage to calculate a current-limiting resistor for it.
audioguru is offline
Old 26th August 2007, 02:02 AM   (permalink)
Well the LED spec says:
Forward Voltage : 3.0v-4.0v
Forward Current : 150mA
Should I assume the lower or upper end of the forward voltage scale ?
yngndrw is offline
Old 26th August 2007, 02:15 AM   (permalink)
How can you assume a voltage? Assume the lowest voltage then most LEDs will be too dim but none will burn out.
You either measure the forward voltage and calculate a current-limiting resistor for an LED or you make a constant current source for it.
Old 26th August 2007, 02:34 AM   (permalink)
Assuming the lower forward voltage will result in a conservative (higher) estimate for the resistor. However, if your supply voltage is not close to 3V (like >6 V), using either value is not going to make much of a difference.
That said, it wouldn't hurt to actually measure it.
pc88 is offline
Old 26th August 2007, 02:54 AM   (permalink)
Okay then I'll measure it, is a constant current source required to measure the forward voltage drop or can I just use a safety resistor which is in a reasonable range ? It's a little embarrassing to have to ask such questions about an LED, but I never really looked into them that much.
Thank you for your help.
yngndrw is offline
Old 26th August 2007, 11:20 AM   (permalink)
Use a proper current source rather than a simple series resistor, then you won't have to worry about the forward voltage providing your regulator can provide the voltage at the lowest supply voltage.
Screen name: Aloone_Jonez
Hero999 is offline
Old 26th August 2007, 02:27 PM   (permalink)
True, I was thinking of just testing how bright it was untill I can get a proper regulator setup, but you're right I may aswell just get a regulator sorted out now - It would be a different brightness anyway.
Thanks everyone.
yngndrw is offline
Old 26th August 2007, 02:49 PM   (permalink)
LM317 and a cheap 9-12vdc ac-dc wall wart can be your constant current source. Its a great setup for bench testing things.
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Help needed on LED driver him27hk General Electronics Chat 22 22nd August 2007 01:09 PM
AD-501-B (w/ LC7932M LED driver ICs) 16x32 LED Display questions tdg8934 Micro Controllers 36 3rd August 2007 02:18 AM
LED Driver anmango35 Electronic Projects Design/Ideas/Reviews 21 27th May 2007 12:39 AM
LED driver for 16 led's mcs51mc Electronic Projects Design/Ideas/Reviews 7 12th April 2007 07:44 PM
LED Driver Problem (STP16C596) Deebo General Electronics Chat 13 21st March 2007 07:04 PM
