| I'm looking for suggestions on bringing 40vdc down to 5vdc The trick is making it run as cool as possible. I could use a switch mode regulator like a National Semi simple switcher but the normal current requirement is less than 1ma and I thought it might be possible and cheaper to use a 78l05, lm317 or similar. The 80ma requirement is to run a latching relay (approx 8 time per hour) I figure a decent filter cap could take on the load. Suggestion , advice welcome. | |
| I would use an LM317, 2.8W isn't that much power so you won't need a huge heat sink. If you want to go down the switching route then I always suggest this site, although the efficiency won't be as good as 93% with 40V in and 5V out.
| You might consider using a 5W zener diode in series, such as 1N5364BG or maybe the next higher voltage one (36V) 1N5365BG.
__________________ The great thing about electronics is unlimited ways to do the job. The only limit is one\'s imagination. I generally think my way is best. Show me a different way. I have an open mind. | |
| Problem is the heat, it's a thermostat afterall. The black regulator is neat but I need it to handle a fairly wide range of power sources. | |
| I have not been able to find these to gauge pricing but they're pretty neat: http://www.recom-international.com/s...or_R-78xx.html | |
| Those switchmode 7805 replacements are cool, but $10 each. I'll play with the black regulator or an LM2575 simple switcher. I should be able to use a low current inductor. | |
| if the load is too less perhaps you may consider simple zenor with series resistor at 5mA overall current and the zenor can geive the requisite load of try using a old MC34063 in switching mode and sure it will serve your needs. Datasheet may be referred at www.alldatasheet.com Sarma Last edited by mvs sarma; 26th August 2007 at 08:01 AM. | |
| Another possibility is this approach: http://www.edn.com/contents/images/61302di.pdf See the article "Linear regulator = low-cost dc/dc converter". Probably not as efficient, but an interesting idea nonetheless. | |
| +5VDC to -5VDC | leonel | Electronic Projects Design/Ideas/Reviews | 24 | 15th September 2005 02:44 PM |
| Trying to find a PCB design program - advice please | HandyMan | Electronic Projects Design/Ideas/Reviews | 9 | 21st February 2005 05:22 PM |
| advice needed... | TKS | Micro Controllers | 1 | 16th February 2005 11:41 PM |
| Give some advice on this, much appreciated ~>_<~ | janetsmith2000@yahoo.com | Electronic Projects Design/Ideas/Reviews | 4 | 26th November 2003 07:32 PM |
| help with my project 5vdc signal to control(interrupt)power | vanko | Electronic Projects Design/Ideas/Reviews | 0 | 25th June 2003 02:23 AM |
