Old 22nd August 2007, 02:25 PM   (permalink)
Default Light control
Hi... I have constructed the following circuit which runs fine on 9V. The circuit responds to light and dims/brightens the LED.
Using this concept, I would like to put this circuit in line with a 120V outlet and power strip and essentially use it as a control valve.
Based on the light intensity, only so much current will flow from the wall socket through the circuit and to the power strip. If the light is totally lit, the full AC current runs through the circuit over to the power strip. As the light dims/increases, the AC current is also diminished/increased.
I need help in modifying the circuit to do this extra "control valve" process.
120V outlet
connected to following circuit
HTML Code:
			+ 9V
		_____________________
		> 150 	        470 >
		|		    __
		|		    \/	LED
		|		    __
		|_________________|/   2N4401
		> PhotoCell	    |
		__________|__________
			_____
			 ___
			  _
adumas is offline
Old 22nd August 2007, 02:38 PM   (permalink)
http://www.epanorama.net/documents/l...ghtdimmer.html
ronsimpson is offline
Old 22nd August 2007, 07:09 PM   (permalink)
Hi... Thanks for the url - I checked it out and read over the material. Very interesting but it seems a bit overwhelming - so many choices / issues...
I'm wondering if the circuit I built can be modified - or if I just have to scrap it all together - which would be a shame.
adumas is offline
Old 22nd August 2007, 07:13 PM   (permalink)
What you built is for 10VDC. Transistors are for DC. A triac is a high voltage AC device.
Old 22nd August 2007, 07:48 PM   (permalink)
ok...
I went back to the url and found their simplist example. It is hard to read but here is the one they referenced. I'm assuming that instead of the 185K pot, I would substitute my photocell. Is that right?
HTML Code:
Black o--------------------------------+--------+
                                     R1 \  |        |
                                  185 K /<-+        |
                                        \  v CW     |
                                        |         __|__ TH1
                                        |         _\/\_ Q2008LT
                                    C1 _|_  Diac    |
                                 .1 uF --- (part of |
                 S1                     |    TH1)   |
    Black o------/ ---------------------+-----------+
Also, this circuit involves a TH1 Q2008LT triac. I searched the web site, All Electronics, and they have a:
Teccor Q4015L5. Alternistor Triac - Specifically designed for applications which are required to switch highly inductive loads. 15 Amps, 400 Volts. TO220 package.
Would this work?
adumas is offline
Touch sensor light control needed geemer Electronic Projects Design/Ideas/Reviews 10 Yesterday 03:51 PM
how to control with 250 light diods by printer port albgaza Electronic Projects Design/Ideas/Reviews 9 14th August 2004 12:26 AM
circuit diagram/schematic diagram of remote light control xhandz Electronic Projects Design/Ideas/Reviews 1 20th June 2004 05:48 AM
traffic light control system samcheetah Electronic Projects Design/Ideas/Reviews 3 3rd May 2004 07:30 PM
R/F remote control switch for light alex76 Electronic Projects Design/Ideas/Reviews 5 6th February 2004 02:58 AM
