| Hello everyone, I am a HAM (as in Amateur Radio), and I now have multiple radios in my van... All is well, except that unless I am looking at the radios (not good to do for long while driving), I cannot tell which radio is talking. Each radio is hooked up to an external speaker; however, the speakers are located next to each other and telling them apart when the transmissions are short is next to impossible. What I would like to do is place a Light Emitting Diode into each of the circuits so I can look up and see at a quick glance which speaker was just active. I am thinking that the LED could light up and then stay illuminated for approx 5 seconds. (Actually, the idea of staying illuminated for 5 seconds is a 'nice to have', but not required.) The external speaker jack on each radio is 8 ohm, calling for a speaker in the 3-10w range. I am using 8 ohm, 5w external speakers. The sound output volume and quality is perfect. Any ideas for something realitively simple that I can drop into the circuits? (I'm pretty good with a soldering iron.) Matt | |
| Why not use the carrier-sense control line already built into the radio? This is the "squelch" output that unmutes your speaker when you receive carrier. Many radios bring a squelch (sometimes also called COR or similar) switch output to an interface connector at the rear of the radio. It would be dead simple to use this to drive a transistor switch which then drives an LED. Have a look at each radio's manual to find pin-out for any rear panel connectors and try to find this squelch or speaker mute output.
__________________ RadioRon | |
| RadioRon - That would be a great idea, but the radios that I have don't have that option (HTX-10 & VX-170). I decided to skip over some of the smaller pieces/calculations and go with National Semiconductor's LM3915N-1 to drive Radio Shack's 10-Segment, Red LED, Bar Graph (276-081). Specs: LM3915N-1 Datasheet (Purchased from Newark) 276-081 Datapage (Purchased from local Radio Shack) I plan on following the diagram on page 22 of the LM3915 datasheet. Does anyone see any problems or concerns that I may have missed or overlooked? (I will be supplying 12v to the LM3915's.) | |
| Your choice of IC and LED parts looks fine. The 12V supply in a vehicle is a nasty environment to power a circuit from, so I would recommend adding an input filter and a regulator IC on the 12V. The best regulator would be a simple linear part that is designed specifically for automotive use but even the common 7808 would be a good choice. I suggest an 8 volt regulator simply because the 78xx series needs an input voltage that is 2 volts or so above the output voltage, and you can't count on the vehicle voltage remaining at 12V when the engine isn't running, so plan on an input of 10V. There are other linear regulators that are the "low drop out" type which only need an input that is about 0.5 volts above the output, but it seems your circuit could work just as well from 8 volts as it would from 10 or 12V. (when you crank your engine, the DC voltage will drop momentarily to as low as 4V and then go up to around 7 to 10V while the starter cranks. Don't expect your circuit to work properly during this time. Those of us designing microprocessor circuits for in vehicles should use a supervisor circuit to reset the processor during these brown-outs) I would also recommend an input filter on the 12VDC input consisting of a a series fuse and a reversed shunt rectifier or power zener (30 volts). The rectifier would be bypassed by a 1000 pF 100 V ceramic cap. Then I would add a series common mode choke followed by a shunt capacitor, say 1 uF 50 voltDC. The fuse followed by the rectifier helps protect against accidental reverse hookup of the 12V DC, while the choke helps reduce alternator whine and other noise . But this may be overkill for your application. The interconnect wiring that you add in your vehicle has the potential to act as an antenna and pick up your radio transmissions and bring RFI into your circuit. So you need to add some simple RF filtering to every wire that enters your circuit, in the form of a 470 pF (or any value from 100 to 1000 pF) 100VDC or higher, bypass capacitor to a good ground point in your new circuit. Put one of these ceramic capacitors from each speaker input to ground, and from 12Vinput to ground. Your ground should be the point where your ground wire from the vehicle attaches. One other thing to watch for is that the circuit in the data sheet assumes that the speaker amplifier is single ended and not a bridge type. A bridge output has two speaker lines neither of which is ground, and you should not attach either side to ground. I don't think this is common in mobile radios. You need to check that. Post again if you don't know how to deal with this.
| speaker phase tester for audio installer | r10069 | Electronic Projects Design/Ideas/Reviews | 16 | 16th February 2008 11:43 PM |
| Good Electronic Supply's Sites, Everyone Come On In! :P | Electric Rain | General Electronics Chat | 44 | 28th August 2007 12:06 AM |
| Simple speaker switches....I need some help. | AdamPrawitz | Electronic Projects Design/Ideas/Reviews | 9 | 30th March 2007 11:23 PM |
| LED ans speakers. | pljack | Electronic Projects Design/Ideas/Reviews | 10 | 19th May 2005 11:10 AM |
| I Wanna switch 1 amplifier between 3 sets of stereo speakers | lcars | General Electronics Chat | 4 | 19th May 2004 10:19 AM |
