| Ok I can't for the life of me figure out why the power supply is having the plus go to the ground. ![]() It's from http://www.geofex.com/Article_Folder...ace/fftech.htm that site. Also why is there a Polar Capacitor from the signal...and how does the signal get biased...or does it? | |
| Nothing with that. There are positive or negative as ground or dual and more supplies. It's designer choice. Polar capacitor and diode are different. Capacitor still work with reverse polarity for small signal (milivolts or even volts). | |
| Ok. Well why is it polar? Yet the other 0.01uF is not? | |
| The original Fuzz-Face circuit used old fashioned germanium PNP transistors. Their circuits frequently had a positive ground. Have you seen how distorted it is? It has clipping at the top and bottom and the bottom has much more clipping. So it has odd harmonic distortion from both top and bottom being clipped and has even harmonic distortion because they are not symmetrical. A little 0.01uf capacitor is never polarized. A big 2.2uF capacitor is frequently a low cost polarized electrolytic type. The input capacitor will have its + terminal at 0v and its - terminal wikll have the negative base voltage of the first transistor on it. Negative feedback biases the circuit a little. Here is a simulation of the circuit slightly modified and with silicon NPN transistors:
| Some old cars had a positive earth but it caused problems with corrosion so the idea was abandoned.
| So it does essentially cut off most of the bottom half then. | |
The circuit we are talking about and one of many mods to it including the version with silicon transistors came from this Fuzz Face article: http://www.geofex.com/Article_Folder...ace/fftech.htm The article analysed that it has assymmetrical clipping. (It used AC128 germanium transistors. Remember them?)
Although they were mainly output transistors for small amplifiers (in push pull with the AC127, and later the better spec AC176), such as used in radios etc. | ||
| I think the AC128 was cased in glass like a light bulb, then surrounded with thermal grease, then covered with the metal can.
| need schematic urgently | ycxxi | Datasheet/Parts Requests | 5 | 3rd December 2007 07:32 PM |
| Aguilar DB680 Bass Pre Schematic | jtallent | Datasheet/Parts Requests | 0 | 5th January 2007 05:26 PM |
| Need help with DIY guitar effect....Hendrix Fuzz Face | headbuttking2 | Electronic Projects Design/Ideas/Reviews | 16 | 1st January 2006 11:16 PM |
| Need of Schematic DC-Dc converter | luxuriesPremier | Electronic Projects Design/Ideas/Reviews | 1 | 15th February 2004 10:10 AM |
| For Sale PIC Programmer Schematic | mysemcon2000 | Micro Controllers | 0 | 18th September 2003 12:14 PM |
