Old 17th August 2007, 06:39 PM   (permalink)
Default fLED as a clock source?
Haven't tried it yet, but was thinking a TTL/CMOS clock source could be made using a cheap fLED a transistor, and resistor. Maybe not a permanent fixure in a finished project, but I don't own a signal generator, nor keep a 555 circuit handy (so easy to throw one together as needed). But thought it might be simple and useful, students might find a use as well.
Figured I'd post this first, and see its been done, before spending much time re-inventing. Have a huge list of things to do this weekend (huricane season is starting to get busy...).
HarveyH42 is offline
Old 17th August 2007, 07:01 PM   (permalink)
whats a "fled"?
this? http://www.solarbotics.net/library/c...e_t1_fled.html
If you don't have a planet, what good are gold bars?
want to contact me directly? gmail gordonthree
check out my project website: http://projects.dimension-x.net
Favorite numbers:
09 F9 11 02 9D 74 E3 5B D8 41 56 C5 63 56 88 C0
justDIY is offline
Old 17th August 2007, 07:16 PM   (permalink)
Flashing LED?
It's pretty simple, just connect a flashing LED and appropriately sized current limiting resistor in series with the base of a transistor with a pull-up resistor connected from the collector to +V and the emitter at 0V. Don't use an LED as the clock if you need decent accuracy, they're worse than a 555 timer.
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th August 2007, 07:29 PM   (permalink)
how about just a momentary switch and a finger? tap tap tap your finger, presto a clock, and it has adjustable frequency!
Favorite numbers:
justDIY is offline
Problem with LCD code? spondootre Micro Controllers 15 29th April 2008 10:15 AM
Clock Source for WaferCard from PIC16F819 TKS Micro Controllers 5 1st March 2006 06:42 PM
Hardcode a PIC by hand? (or 16F74 + par.port.prog = problem) smilen Micro Controllers 15 21st November 2005 10:23 AM
Cardreader Clock Source TKS Micro Controllers 3 5th April 2005 12:26 AM
Help me on basketball's game clock and shot clock! syaw_007 Electronic Projects Design/Ideas/Reviews 1 6th September 2004 10:50 PM
