Old 17th August 2007, 03:57 PM   (permalink)
Default Random LED flasher
Can anyone help me build a random 2-LED flasher?? I've seen projects for flashing LED's but they all have fixed intervals... what I'm looking for is a circuit that would flash 2 LED's at the same time then flashes again with indefinite intervals... around 1 - 2 seconds intervals would be fine but again, random... your help will be greatly appreciated...
grandmasteralok is offline
Old 17th August 2007, 06:19 PM   (permalink)
So both led's ALWAYS flash at the same time?
TrevorP is offline
Old 17th August 2007, 06:22 PM   (permalink)
Maybe not as complicated as you are looking for... but, I once bought a bunch of flashing red LEDs cheap ($5/100). They seem to flash ar different frequencies. I've been using 5 wired in parallel to discharge a small rechargable lithium battery I have been playing with for a couple of weeks (using LEDs as solar cells). Get pretty interesting, and apparently random patterns.
There are are dozens of 2 transistor circuits to flash LEDs on the web, will take a look later, might have on on my HD to post. But if you put together 2 identical circuits, they will flash at slightly different frequencies due to component tolerances (caps and resistors).
Have seen, and likely have a copy, of a circuit using a 4xxx CMOS chip, that flashes randomly. Just seemed like a lot of pins for something I could do with an 8-pin AVR chip.
HarveyH42 is online now
Old 17th August 2007, 09:04 PM   (permalink)
that's right... i want to flash a red and orange LED at the same time... no programming please.. i dunno anything about that stuff...
Old 18th August 2007, 02:44 AM   (permalink)
I do not know of any LEDs that blink randomly. My LEDs have a blink rate or a blink pattern.
Is this an experiment? Do you have an application where thousands will be used?
ronsimpson is offline
Old 18th August 2007, 05:28 AM   (permalink)
What you want is a pseudo random number generator. Adapt something like this to drive the LEDs:
http://www.maxim-ic.com/appnotes.cfm/an_pk/1743
kchriste is online now
Old 19th August 2007, 05:59 AM   (permalink)
You can build a simple psuedo random generator with some flip flops or shift register ICs. For example, my old Forrest Mims "Engineers Notebook" has a simple pseudo-random generator circuit that uses a pair of 4021 logic ICs fed by a simple RC clock. There are many variants using shift registers of all kinds. Here is one (scroll down a ways):
http://www.doctronics.co.uk/4015.htm
RadioRon
RadioRon is offline
Old 19th August 2007, 04:41 PM   (permalink)
Use white noise and a comparator set at a certain level.
Screen name: Aloone_Jonez
Hero999 is offline
Old 20th August 2007, 02:25 AM   (permalink)
i think can use IC 555
logto is offline
36 LED Sequencer HELP NEEDED aquaviventi General Electronics Chat 6 20th August 2007 02:28 AM
Problem in LED Flasher in pic 16F877A rakan Micro Controllers 6 7th April 2007 11:45 AM
Flashing a LED with Mouse Gayan Soyza Electronic Projects 12 28th March 2007 11:54 PM
Accessing EEPROM Clayton Micro Controllers 15 23rd March 2007 04:00 AM
Random White Multiple LED flasher amimator Electronic Projects Design/Ideas/Reviews 1 3rd April 2004 04:21 AM
