Old 17th August 2007, 03:00 PM   (permalink)
Default need help about relay!!
in this circuit FWD/RVS relay is shown with 2 separate contact pins and 2 separate NC and NO pins...
i wanna ask whether they are using 2 relays with one transistor or configuration of relay is just like that internally..?
msovais is offline
Old 17th August 2007, 03:03 PM   (permalink)
It's two relays, and clearly shown as such. One is used for ON/OFF and the other for reversing.
Old 17th August 2007, 03:06 PM   (permalink)
i m not talking abt above power relay..
the 2nd FWD/RVS relay...???
msovais is offline
Old 17th August 2007, 03:10 PM   (permalink)
It's a DPDT relay, also called a 2 pole changeover, again it's clearly marked as such, by the dotted line from the coil to the contacts. It's a standard relay!.
Old 17th August 2007, 03:12 PM   (permalink)
Thumbs up
yeah.. nigel is right
hamm3rst0rm is offline
Old 17th August 2007, 03:17 PM   (permalink)
hmm...in this case if i dont use that relay...can i use two simple relays with one transistor?
msovais is offline
Old 17th August 2007, 03:54 PM   (permalink)
You could use two single pole changeover relays - assuming you already have them? - if not you may as well get the correct relay, like I said they are VERY common.
Old 17th August 2007, 06:21 PM   (permalink)
im not been able to switch two single pole relays with one transistor(2n2222).
msovais is offline
Old 17th August 2007, 06:52 PM   (permalink)
What are your base drive voltage inputs, if they are +5V, its most likely that with a 10K base resistor you are not driving the 2N2222 into saturation, when you have two relay coils in parallel.
Whats the supply voltage to the relays and what is the coil resistance?
Eric
ericgibbs is online now
Old 17th August 2007, 07:02 PM   (permalink)
Do you have the mandatory free-wheel diode connected in reverse parallel?
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th August 2007, 08:48 PM   (permalink)
The relay might be a honking huge one for switching on a winch. The poor little 2N2222 will curl up and die.
audioguru is offline
Old 17th August 2007, 09:43 PM   (permalink)
Well we are lacking almost all information!
Old 17th August 2007, 11:37 PM   (permalink)
pretty much, he has thrown a circuit at us, and is asking how to avoid using a relay, because he doesn't have one. wouldn't you think if the circuit COULD use transistors, they would, since transistors are much faster, and sometimes more reliable???
just buy or find a relay somewhere, they would only be a couple of bucks, and it would save you all this trouble
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 18th August 2007, 12:16 AM   (permalink)
Those diodes are protection from the relay right?
TrevorP is offline
Old 18th August 2007, 12:23 AM   (permalink)
Connect a 9V relay to a 9V battery. Then hold the relay's wires in one hand and disconnect the battery. You will feel a big shock (don't use both hands or it might kill you).
The voltage when the relay is disconnected might be hundreds of volts that could destroy a driver transistor. Adding a reversed diode across rhe coil clamps the voltage spike to 0.7V more than the positive supply voltage.
Need a relay controller rtm038 Electronic Projects Design/Ideas/Reviews 14 18th November 2007 06:20 AM
Relay Control Via Transistor Problem iso9001 General Electronics Chat 9 31st August 2004 01:26 PM
Relay Connections Johnson777717 General Electronics Chat 2 7th July 2004 10:45 PM
MCU controlling relay (or a way to simulate a SPDT relay?) LiquidKernel Electronic Projects Design/Ideas/Reviews 5 25th March 2004 04:10 PM
Incubator Relay Circuit Plip Electronic Projects Design/Ideas/Reviews 2 26th November 2003 01:36 PM
