Old 18th August 2007, 08:16 AM   (permalink)
To add to this post is that the first TX is connected to L1 and L2, the second TX to L2 and L3, the third TX to L3 and L1 to keep the system balanced.
For the SWER the same applies.
The isolating TX is supplied from 2 phases. The output is 1 phase and the other terminal is earthed.
The isolating TX is used to avoid tripping the line protection on earth fault.
RODALCO is offline
Old 18th August 2007, 12:08 PM   (permalink)
Originally Posted by RODALCO
The system Hero999 describes is also used a lot in rural New Zealand.
From the 3 phase line a 2 phase transformer with secondairies of 2 x 230 Volts or 2 x 240 Volts is used with the windings in parallel.
With the windings in series 460 or 480 Volts can be taken off for a 1 Ø motor with an extrernal capacitor to create the phaseshift.
In the second case the neutral will be on the link between the secondairies to keep the phase to neutral; voltages below 250 Volts.
This set up is also used on the SWER systems which have only a 1 phase line fed from an isolating TX at a voltage of 6.6 or 11 kV.
I think you're missing the point. That's a split phase system, not a two phase system.
Screen name: Aloone_Jonez
Hero999 is offline
Old 18th August 2007, 10:50 PM   (permalink)
Correct! with the common neutral the phases are 180° apart. we refer this as a 1 Ø system for the secondary, regardless if 230 or 460 Volts is supplied.
For the primary, it is a single phase supply taken of 2 phases of the network.
RODALCO is offline
Old 27th October 2007, 02:58 PM   (permalink)
You may get away with connecting a diode in series with the charger, without knowing exactly how your charger is designed it would be all guesswork. If it is an 'international' charger it may have a doubler inside, but it is likely that an autotransformer is your answer here.
Gordz is offline
Old 27th October 2007, 03:38 PM   (permalink)
Never connect a diode in series with anything other than a resistive load such as a heater of incandescent lamp.
If the charger has a transformer on the input it'll go into core saturation and melt down.
If the charger uses a switch mode power supply then the higher input voltage will pop the capacitors and destroy the switching transistors.
The only way of powering anything other than a simple resistive load of a higher voltage source is to use a transformer.
Hero999 is offline
Old 27th October 2007, 07:13 PM   (permalink)
The Lithium battery charger has a 3A low voltage output. Since it is probably a single "3.6V" cell then the charger's max output voltage is 4.2V and the power is only 12.6W.
If the charger has a very poor transformer then its primary power is 25W.
A stepdown transformer that is 230V to 110V at only 25W is small.
audioguru is online now
Old 28th October 2007, 12:15 AM   (permalink)
Yeah, but how many 25VA 230:110V transformers have you seen?
100VA is normally the smallest size they come in.
Hero999 is offline
Time Delay Relay Circuit.....is this doable? Draguen General Electronics Chat 14 31st August 2005 05:02 PM
Motor Controlling Circuit Required Nab AC Analysis Electronic Projects Design/Ideas/Reviews 5 26th September 2004 12:51 AM
Circuit required for 2 digit Anode Display Gregory General Electronics Chat 1 21st January 2004 10:07 PM
A Circuit Required to Control 2 52mm red LED cluster Array Grzyb Electronic Projects Design/Ideas/Reviews 4 28th October 2003 05:45 PM
On-time delay circuit using LM555 mozikluv Electronic Projects Design/Ideas/Reviews 9 24th October 2003 02:45 AM
