| Interesting discussion going on here. Most of Europe is standardised to 230 / 400 Volts. I know of some older cities in The Netherlands where still some 127 / 220 Volts ( 120 ° phase shift) networks was in place ( Dordrecht, Leiden, Amsterdam ) about 20 years ago, I have worked on them because i done a rewire by a family member. The 127 Volts is rarely used but 130 Volts lightbulbs there seem to last forever. The power points were ran at 220 V Ø to Ø, and the lighting at 127 V between phase and neutral. These systems were gradually phased out to 220 / 380 and now 230 / 400 Volts at 50 Hz. O.T. In remote parts of Italy there are 150 - 160 / 275 Volts networks in place. Occasionally there are old lightbulbs and kWh meters for sale on Ebay Italy. Then I own one of the Italian distrubution networks books where these systems are described in detail. But for above thread. Get a 240 / 110 Volts transformer (safest). or buy a charger with the required low voltage output to charge your batteries ( Jaycars) He sais he lives in Adelaide where the mains voltage is at least 240 V and may even be 250 V. edited for typo's
__________________ There are more ways to get to Rome. Electricity, Electric clocks, Meters and Trains are great. | |
And I thought it was 120 degrees for two phase ? | ||
| Wait a minute. 330W to charge a little battery? No way, man! The 3A is probably the OUTPUT of the lttle 110V charger, not its input. The voltage output of the charger times 3A and then double it would be the power required from a small auto-transformer for it.
| It's understandable how to came to that assumption but it's incorrect. A split phase system ![]() http://en.wikipedia.org/wiki/Split_phase A two phase system There's no fancy picture here but I'll offer two simple quotes: "Two-phase electrical power was an early 20th century polyphase alternating current electric power distribution system. Two circuits, or "phases", were used, with voltages 90 electrical degrees apart in time." ---snip---- "Three-wire, 120/240 volt single phase power used in the USA and Canada is sometimes incorrectly called "two-phase". The proper term is split phase or 3-wire single-phase." http://en.wikipedia.org/wiki/Two_phase
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. Last edited by Hero999; 17th August 2007 at 10:09 PM. | |
As for the American system being incorrectly called 'two phase', I would have thought it's a better, more sensible, name for it - and makes more sense than reserving the name for a long obselete system?. I'm presuming they don't still use that antiquated system for driving motors anywhere?. | ||
| I don't know. The term split phase makes perfect sense to me - it's a single phase split by a centre tapped transformer.
| By two phase, I ment if you take a three phase supply and connect across two of the phases. It is unbalanced but you have about 415V. I've always known that as two phase anyway, it's used in some factories. | |
Presumably it's been specifically installed for that use, with a solid neutral?, which you wouldn't normally have. | ||
| I've seen them used in dairy farms where full three phase with neutral is available. The three phase is used through a star-delta timer to drive the main milk separator while the two phase motors are used in small(ish) pumps. I guess it's to reduce the cost of the motor. I've never really asked why, I was just helping my dad build the controllers. Looking at a graph of a three phase sine wave, two phase should give a peek voltage of about 75% of the full peek voltage. | |
Normally you use a three phase plug but only use two of the pin and as Nigel says, the electricity company won't happy if you draw huge loads from one or two phases, there again it's just as likely that someone else is drawing just as much power from other phases to roughly ballance it out.
__________________ I also post at the following sites: http://www.stop-microsoft.org http://www.heated-debates.com Screen name: Aloone_Jonez And http://www.silicontronics.com, same screen name as here. | ||
Peek is entirely different, although you might 'peek' at a milk maid. | ||
Of course, to obtain the "foward" (0º) and the "reverse" (180º) voltages they use a split phase transformer The 90º phase can be obtained (from a three phase system) with some exotic connections: for example if you take one phase (0º - 180º) between two of the 3 phases, between the third phase and the neutral you have 90º. Of course, it's only a means to drive the motor. a two phase motor (90º) is a polyphase motor (like a 3 phase one). With an split phase supply (180º) you have to use a single phase motor. A single phase (induction) motor needs some auxiliar starting system (2nd winding, capacitor, shadow pole, etc) Power distribution is allways a three phase system. (with or without a "star centre" neutral) or, for short distances and small loads, a single phase system (or may be split phase).
__________________ E Cerfoglio Buenos Aires Argentina | ||
| The system Hero999 describes is also used a lot in rural New Zealand. From the 3 phase line a 2 phase transformer with secondairies of 2 x 230 Volts or 2 x 240 Volts is used with the windings in parallel. With the windings in series 460 or 480 Volts can be taken off for a 1 Ø motor with an extrernal capacitor to create the phaseshift. In the second case the neutral will be on the link between the secondairies to keep the phase to neutral; voltages below 250 Volts. This set up is also used on the SWER systems which have only a 1 phase line fed from an isolating TX at a voltage of 6.6 or 11 kV.
| Time Delay Relay Circuit.....is this doable? | Draguen | General Electronics Chat | 14 | 31st August 2005 05:02 PM |
| Motor Controlling Circuit Required | Nab AC Analysis | Electronic Projects Design/Ideas/Reviews | 5 | 26th September 2004 12:51 AM |
| Circuit required for 2 digit Anode Display | Gregory | General Electronics Chat | 1 | 21st January 2004 10:07 PM |
| A Circuit Required to Control 2 52mm red LED cluster Array | Grzyb | Electronic Projects Design/Ideas/Reviews | 4 | 28th October 2003 05:45 PM |
| On-time delay circuit using LM555 | mozikluv | Electronic Projects Design/Ideas/Reviews | 9 | 24th October 2003 02:45 AM |
