Old 17th August 2007, 02:49 AM   (permalink)
Default Fixed Bench PSU
Well I want to make a simple bench PSU which will give out: +-12V @ 1A and +-5V @ 1A.
Looking through my CPC catalogue, I've made the following design [Attached]. (Although the -12V is now limited to 0.5A, due to the limitations of CPC.
Parts list and prices:
Parts list (CPC Part Numbers) - Prices in GBP, excluding VAT
[ Ref			- CPC Part #	- Description					- Price (Total) ]
T1			- FF01553	- 60VA Toroidal 2x15V				- £10.85
BR1			- SC05773	- KBPC601 (50V, 6A Bridge Rectifier)		- £1.97
RG1			- SCL78S12CV	- L78S12CV (+12V, 2A Regulator)			- £0.99
RG2			- SCL7912CV	- L7912CV (-12V, 1.5A Regulator)		- £0.72
RG3			- SCMC7805CT	- MC7805CT (+5V, 1A Regulator)			- £0.26
RG4			- SC05482	- MC7905CT (-5V, 1A Regulator)			- £0.39
C1 & C2			- CA04567	- Aluminium Electrolytic 2200uF 50V		- £3.10
C3 & C7			- CA04503	- Aluminium Electrolytic 3.3uF 50V		- £0.20
C4 & C8			- CA04506	- Aluminium Electrolytic 22uF 50V		- £0.26
C5 & C9			- CA04501	- Aluminium Electrolytic 1uF 50V		- £0.20
C6 & C10		- CA04558	- Aluminium Electrolytic 10uF 50V		- £0.14
D1			- LP00348	- 12V 5mm Green LED				- £1.37
SW1
F1			- FF00394	- 3.15A TD 1 1/4" Fuse (10 Pack)		- £1.18
F2 & F4 & F5		- FF01404	- 1A QB 20mm Fuse (10 Pack)			- £0.58
F3			- FF01393	- 500mA QB 20mm Fuse (10 Pack)			- £1.13
*Others:
Fuse Holders (x4)	- FF01330	- 20mm Fuse Holders (x4)			- £1.04
Mains Inlet		- CN09935	- Power Socket, Fuse Holder, Switch Module	- £3.25
Regulator Insulators	- SCW353PK	- TO-220 Insulators (10 Pack)			- £1.85
Case
Heatsink
*Total Price (+Case and Heatsink):
Without VAT	= £29.48
With VAT	= £34.64
Questions:
1) Suggestions / Improvements ?
2) What size heatsink would I need for ALL the regulators AND the bridge rectifier ? Note: The regulators and bridge rectifier will be mounted to the side of a small die-cast aluminium case, with the heatsink bolted to the outside.
Thanks,
-Andrew.
yngndrw is offline
Old 17th August 2007, 03:07 AM   (permalink)
Why bother building it? Any old PC power supply will meet those requirements. They're easy to modify with a few binding posts and a toggle switch.
straight answer, har har."
Sceadwian is offline
Old 17th August 2007, 03:21 AM   (permalink)
You have a good point, before I started designing and pricing it up, I expected it to be a LOT cheaper. The problem with a PC PSU is that the output is "noisey".
I have quite a few old PSU's lying around, guess I might just make a nice case for one.
Thanks.
yngndrw is offline
Old 17th August 2007, 07:29 AM   (permalink)
Originally Posted by yngndrw
Questions:
*It is better to use an 18V transformer.
*Don’t you like to put the POWER ON LED near one of the 2200uF capacitor?
But when comparing the size, price & the transformer it’s worthwhile to convert an ATX power unit for your workbench like Sceadwin points out.
Here some useful links to you.
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
http://web2.murraystate.edu/andy.bat...OWERSUPPLY.HTM
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 17th August 2007, 11:49 AM   (permalink)
Never realised a PSU would need such headroom, so thanks for pointing that out.
The reason for the LED's position is it's more of a PSU Is Ok LED, so if both the +5V and -5V rails are working, you can assume that the rest of the PSU is working fine.
Thanks for the links, I would have forgotten to put a load resistor on it without them.
yngndrw is offline
Old 17th August 2007, 03:22 PM   (permalink)
Thanks.
Then use a filter consisting of capacitors ferrite beads and common mode chokes.
Screen name: Aloone_Jonez
Hero999 is offline
Old 17th August 2007, 03:41 PM   (permalink)
True true, that sounds like the best option. A lot cheaper than building one anyway.
Thanks.
yngndrw is offline
Bench Power Supply leorick Electronic Projects 7 2nd July 2007 10:54 PM
CPU PSU and 14.4V drill Hank Fletcher General Electronics Chat 2 30th April 2007 06:48 AM
First scratch built bench power supply Revolvr Electronic Projects Design/Ideas/Reviews 3 22nd January 2007 12:38 AM
PSU Bench Supply Control Circuit computer Electronic Projects Design/Ideas/Reviews 3 30th December 2004 07:25 PM
Bench PSU ante Electronic Projects Design/Ideas/Reviews 9 30th January 2004 10:25 PM
