Old 15th August 2007, 03:41 AM   (permalink)
Default Motor control
I am pretty new to this but i will give it a try. i want to control a DC motor's speed and direction so i looked up ideas on google and i decided to purchase this . After assembly and checking the circuit over and over again i hooked up the motor and the power source. I am using 12v at 500 mA power source and the motor is rated for 6 volts. When everything is connected i get nothing out of the motor. Do i need to up the voltage or is there something else i need to do. Please help
jokoboy is offline
Old 15th August 2007, 11:04 AM   (permalink)
For a 6V motor 12V supply is too high. It is good if you can apply the same voltage that needs to the motor.
If you sure with your MOTOR then the problem with your kit.
You are lucky all the components are well marked & no HIDDEN or name ERASED components. So easily can repair.
Mostly target devices that can cause to burn are the two MOSFETS & the LM324 in your circuit. Try replacing them.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 15th August 2007, 11:18 AM   (permalink)
i'd imagine that 12v would still work though. just check over everything really well, and if it's all good, it's either your motor is ruined, or you power supply is dead?
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserpointerforums.com A forum for disscusion of lasers and laser shows!
www.laserchat.org IRC chat for laser and electronic related stuff.
things is offline
Old 15th August 2007, 06:48 PM   (permalink)
Have you tested the motor separately on a 6V supply?
Have you tested the controller with a different 12V motor?
Screen name: Aloone_Jonez
Hero999 is offline
Old 15th August 2007, 08:40 PM   (permalink)
ya i have tested the motor on a 6 volt and a 12 volt supply and it works with both. i think i will try and replace the MOSFETS and see what happens.
jokoboy is offline
Old 15th August 2007, 11:04 PM   (permalink)
What about the controller though?
If you don't have a spare motor you could use a 12V incandescent light bulb and test to see if it dims properly at lower speed settings.
Hero999 is offline
Old 16th August 2007, 04:10 AM   (permalink)
yep tried two diff motors nothing coming through. think i must have a bad connection or something. thanks for the help though
jokoboy is offline
Old 16th August 2007, 04:52 PM   (permalink)
Talking Jokoboy
if u want to control the speed and rotation of the motor why not hook a potentiometer to it? or put a reverse bias to it with a diode? then wire it up..
__________________________________________________ __________
Death comes to all, bidden or unbidden.. live as if it were true, then live as if it were untrue... keep logic in proper sequence
hamm3rst0rm is offline
Old 16th August 2007, 04:57 PM   (permalink)
DO NOT connect a motor to a pot. The pot will burn out.
A reverse-biased diode in series with the motor won't pass current so the motor won't run.
Death comes to all, bidden or unbidden.. live as if it were true, then live as if it were untrue... keep logic in proper sequence[/quote]
audioguru is offline
Old 16th August 2007, 08:35 PM   (permalink)
yep tried the whole POT deal awhile back and it burned it right up lol
jokoboy is offline
