Old 15th August 2007, 10:06 AM   (permalink)
Originally Posted by browningbuck
okay, yes that would work, BUT is there a curcuit out there that can do the same thing. i want this to be electronically controlled. is it possible? i like the "if then" idea of it.
Then use a RELAY its controlled by voltage.
Gayan
My Website
http://gsmicro.blogspot.com/
Gayan Soyza is offline
Old 15th August 2007, 06:10 PM   (permalink)
okay so the red is hard wired in to the bikes system, i do not want to cut the wire, rather just connect the 555 and relay or what ever to it , i understand that that switch would be the easiest method, but all i want is one wire coming from the 555 to a single throw switch, then i can connect the other end to a power source.
this whole system, red, blue, 555, and relay(what ever it is i use) will all be in a very compact area. not that this matters, but just so you know. i can beilive that the only solution in the world of electronics is this switch.....i thought that there would be a simple little gate or something, or relay, that could do this with out a problem
browningbuck is offline
Old 15th August 2007, 11:45 PM   (permalink)
I don't think you can accomplish what you want to do without splicing something into your brake light circuit, and this will mean either cutting a wire or desoldering something.
Now, if you only want two wires going to your activation switch, just have the switch activate a DPDT relay. Relays can be very small, and they're used all the time in automotive applications.
pc88 is offline
Old 22nd August 2007, 10:00 PM   (permalink)
Would a DPDT relay work like this??? if so how do i wire up the DPDTrelay to achive this?
Old 22nd August 2007, 11:17 PM   (permalink)
Yes, a DPDT relay will work like that. Just hook it up like I diagrammed in my second posting of Aug. 14th. The relay will have two other connections for the coil. When current flows through the coil, the switch contacts will move from their "up" position to their "down" position. A spring will restore the switch contacts to the "up" position if current stops flowing through the coil.
Just get yourself a DPDT relay that has a clear case so you can see what's going on inside - that should clarify a lot of things.
pc88 is offline
Old 23rd August 2007, 12:09 AM   (permalink)
PC88 i knew you were right i was just seeing if there was anything out there other thatn this. however this is the simplist and most practical that i can come up with, okay its the only thing i can come up with. ill go play with one today
Old 23rd August 2007, 02:39 AM   (permalink)
cause im a dumb ass pleas some one show me how this 8 pin thing works
Old 23rd August 2007, 04:06 AM   (permalink)
i cant believe i cant find anything on the net for this
Old 23rd August 2007, 08:28 PM   (permalink)
Hey PC88 help me out with these Pins so i know where to wrie it up to i have tried a lot of configurations but non that work. I also got to thinking and do i need a DPDT or just a DPST being it is always on then the throw switches it over???
Old 23rd August 2007, 11:12 PM   (permalink)
What 8-pin thing are you talking about? A relay?
Every relay has its own pin-out. At the very least you'll have to show me what it looks like.
pc88 is offline
Old 24th August 2007, 12:25 AM   (permalink)
nice camera hard at work please dont make fun of me cause i couldnt get this going but here isthe relay
Old 24th August 2007, 03:59 AM   (permalink)
If you must use an all electronic version you could use a power PNP to light the LEDs:
I did not test this, but I don't think there are any reasons why it wouldn't work... It also is an example of a circuit that I don't really like but it's quick and dirty.
R1=1.5K ohm, 1/4 watt
Q1=any high current low voltage PNP-Darlington like TIP125. You may be able to get away with a non-darlington with 560 ohm, 1/2W resistor and a crappy transistor like a TIP42.
all other components are as you need. May have to tweak some of the values/transistors depending on your load.
I did not draw in the rest of the 555 circuit.
P.S. : Having blue lights on your car can get you ticketed. If you get a ticket for impersonating a cop, don't say I didn't warn you...
boxer4 is offline
Old 24th August 2007, 04:59 AM   (permalink)
oh i am very aware of this, i am creating a police bike that will be used on the track as a pace bike
Old 24th August 2007, 07:49 AM   (permalink)
For starters try this:
left COM: Vcc
left NC: supply to RED led array
left NO: unconnected
right COM: Vcc
right NC: unconnected
right NO: supply to BLUE led array
coil unenergized => RED led array is active
coil energized => BLUE led array is active
pc88 is offline
Old 25th August 2007, 07:06 AM   (permalink)
i get constant red, but cant get it to activate and flip over
Touch Sensitive Switch (Take 2) MonkeyMera Electronic Projects Design/Ideas/Reviews 7 2nd October 2007 11:05 PM
Button Debounce Coding help Suraj143 Micro Controllers 25 4th August 2007 10:49 AM
Please help me in writing code abdosat2000 Micro Controllers 9 5th June 2007 02:41 PM
PIC Switch Management Techniques Mike, K8LH Micro Controllers 2 28th September 2006 01:33 PM
