Old 13th August 2007, 09:04 PM   (permalink)
Default radio tuning quesiton
I've built Harry's (SM0VPO) FM microphone:
http://web.telia.com/~u85920178/tx/bug5.htm
It doesn't have the greatest frequency stability, but that's not what I'm concerned about right now. What I'm interested in is understanding the following phenomenon:
I turn on the transmitter and a nearby radio. I tune the radio until I get to an unusually quiet frequency. I verify I'm at the transmitter's frequency by turning off the transmitter, and usually I'll hear static. I have the microphone disconnected so only the carrier frequency is being transmitted.
With the transmitter on, I place a small (1" x 1") piece of copper clad near the transmitter's pcb coil. This no doubt changes the transmitter's frequency. By varying the distance between the coil and copper clad I can change what I hear on the radio. At certain distances I can tune in a station; at others I'll get static; too far away and I'll get silence.
So what's going on? Is there any frequency mixing involved? Is the transmitter amplifying the broadcast signal so that the radio picks it up even though it's tuned to a different frequency? I'd really like to understand what's happening!
pc88 is offline
Old 13th August 2007, 10:11 PM   (permalink)
The copper plate changes the load on the transmitter which detunes the transmitter. This is because the aerial is driven directly from the oscillator. A real transmitter doesn't suffer from this because it has a buffer before the aerial to isolate the oscillator from changes to the load.
As far as picking up other stations is concerned, I don't know what's causing that. Perhaps the non-linear characteristics of the transistor in the oscillator are causing demodulation of the radio station which is immediately remodulated by the oscillator and thus broadcast on a different frequency.
Screen name: Aloone_Jonez
Hero999 is offline
Old 14th August 2007, 06:02 PM   (permalink)
well, I found this tidbit about images being created in the presence of strong signals:
http://cappels.org/dproj/FMXMTR/fmxmtr.htm
(see "A note about FM receivers" at the bottom of the page)
The receiver I'm using is a 20-year old Radio Shack combination portable radio/tape player, but perhaps the same thing is going on (?)
pc88 is offline
Old 14th August 2007, 07:15 PM   (permalink)
That makes sense.
What type radio did you use to listen to your transmitter on?
To stop the frequency from drifting too much you should build a transmitter with an output amplier like the circuit in the link you posted.
Hero999 is offline
AM Radio troubles when testing CParsec General Electronics Chat 2 18th January 2005 02:33 AM
needed: simple radio schematics { antonio } Datasheet/Parts Requests 2 10th January 2005 06:24 AM
Old Radio Shack P-Box Schematics brokepoker Electronic Projects Design/Ideas/Reviews 1 23rd July 2004 06:07 PM
Digital Tuning Radio Interface with LCD slv440 Electronic Projects Design/Ideas/Reviews 0 14th February 2004 05:55 PM
my FM radio has frequency problems. mstechca Electronic Projects Design/Ideas/Reviews 3 21st April 2003 12:01 PM
